Toymods » Tech & Conversions » stud change paten from 5 / 100 to 5 / 114.3
toy.car
adelaide
stud change paten from 5 / 100 to 5 / 114.3 Sat, 23 August 2003 10:12 Go to next message
ok this can be done so im told now all i need is the right information,
spaces with new paten?
change hubs?
where ? who much?
oh its for a gt4 st185 celica
celicafan
Perth WA
Re: stud change paten from 5 / 100 to 5 / 114.3 Sun, 02 November 2003 07:11 Go to previous messageGo to next message
Hi mate, I need to do it too,,, 5 x 100 to 5 x 114.3 conversion that is. only mine is for a st162.
Did you have any luck?
if so please help!!!
thanks in advance Smile
celicafan
Perth WA
Re: stud change paten from 5 / 100 to 5 / 114.3 Sun, 02 November 2003 12:01 Go to previous messageGo to next message
Come on guys! enough of you are reading this... how 'bout some ideas! Come on, even if you thinks its dumb, anything could help!
Re: stud change paten from 5 / 100 to 5 / 114.3 Sun, 02 November 2003 22:46 Go to previous messageGo to next message
This is largely irrelevant, but I thought I'd mention it anyway Very Happy I'm changing thee stud pattern on my Sprinter from 4x114 to 5x114. I dropped off my axles at my favourite diff place last Monday, picked them up on Friday, and they'd done a lovely job. That was until I got them home, and discovered some poor bugger had drilled a 5x120 not a 5x114.3... They're not gonna be happy to see me back again!
ed_ma61
Lost in the K hole
Re: stud change paten from 5 / 100 to 5 / 114.3 Sun, 02 November 2003 23:07 Go to previous messageGo to next message
cant use spacers without changing your offset
you can try sourcing hubs off a different vehicle, but good luck - me thinks youd be on your own with that one Smile
ed
wagonist
Toymods Club Treasurer
Re: stud change paten from 5 / 100 to 5 / 114.3 Mon, 03 November 2003 02:52 Go to previous messageGo to next message
I'm curious to know why?
Is it because of wheels, brakes, ...?
BTW my car has same 5/100 pattern, & the wheels I've got now wouldn't clear my original single piston brakes, but did clear the twin piston ST185 ones due to the different caliper design.
LBack
Re: stud change paten from 5 / 100 to 5 / 114.3 Mon, 03 November 2003 07:00 Go to previous messageGo to next message
check out this site.
http://www.technotoytuning.com/t3_site_pages/produ cts/wheel_adapters.html
peace...
celicafan
Perth WA
icon10.gif  Re: stud change paten from 5 / 100 to 5 / 114.3 Mon, 03 November 2003 08:42 Go to previous messageGo to next message
K dudes,
Did some enquiring today at my local wrecker and a good mechanic.
You need the hubs/rotors off a wide body V6 camry Smile they are 5 x 114.3 and fit quite nicely so I'm told.
Now I wait for the "Hi mate, it's going to be a little harder than I thought" phone call from the mechanic!!
keep you posted.
Rex_Kelway
Re: stud change paten from 5 / 100 to 5 / 114.3 Tue, 04 November 2003 08:32 Go to previous messageGo to next message
Ok then, coming from my angle (I need to change a set of cortina Hubs from 4x108 to 4x114.3). A stud pattern change is as simple as this.
Press out the original studs and weld up the original holes. Then take the freshly blanked hubs to a machine shop or anyone with a precision drill press and have them drilled to my desired PCD. Then re-press wheel studs and smile.
ed_ma61
Lost in the K hole
Re: stud change paten from 5 / 100 to 5 / 114.3 Tue, 04 November 2003 10:29 Go to previous messageGo to next message
except welding up holes in a CAST hub is bloody difficult to do properly...
Bugman
Re: stud change paten from 5 / 100 to 5 / 114.3 Tue, 04 November 2003 10:36 Go to previous messageGo to next message
right on ed.. ofcourse I could just use bubble gum Smiley =
spectral
Re: stud change paten from 5 / 100 to 5 / 114.3 Tue, 04 November 2003 23:28 Go to previous messageGo to next message
celicafan: Does that include the rears?
celicafan
Perth WA
Re: stud change paten from 5 / 100 to 5 / 114.3 Sun, 09 November 2003 14:18 Go to previous message
yeah rears too....
only the "it's gonna be a bit harder" call DID come!!!
the dude needed to do some funky s!#t wit the front inner wheel bearings. other than that said it was easy.
Previous Topic:will my box gear fit into an r154?
Next Topic:1JZ Power Steering Cooler
Current Time: Thu Oct 22 06:54:44 UTC 2026
Total time taken to generate the page: 0.0081760883331299 seconds
