Toymods » Tech & Conversions » Installing rear swaybar
Installing rear swaybar Sun, 24 August 2003 05:51 Go to next message
Hello, wanted to ask a quick question in regards to fitting my rear swaybar.
Its a shelby sway bar that attaches to the lower trailing arms. There are 2x d-style bushes for each arm.
With this design, you can move the sway bar around quite a bit as the D bushes can slide up and down the trailing arms. Is there any set place to put it? Like should it be in-line with the rear of the diff. Or more forward? Also I'm assuming that you should have the mounts as far apart as possible or close together?
Joel
Re: Installing rear swaybar Sun, 24 August 2003 05:59 Go to previous messageGo to next message
Here is some pics of the components. Might make my above question easier to understand!
http://members.optusnet.com.au/helenfitz/rearsway.jpg
Classique71
Colac, Victoria
Re: Installing rear swaybar Sun, 24 August 2003 06:47 Go to previous messageGo to next message
that looks alot different to the one i had on my ta22 - but the principal seems the same - it looks like it will have some movemebr - but oncce the bar is strapped onto the panhard rods - there shouldnt be much at all ..
The one i had was the hangdown type - it bolted around the diff -and onto the front panhard bar mounts ..
Made So much of a difference to the rear end balance - it was amazing !
Im so lookig forward to getting a decent rear bar in the gt4 Smile
Re: Installing rear swaybar Sun, 24 August 2003 07:19 Go to previous messageGo to next message
Yeah a lot ive seen bolt to the diff or chassie but this one just attaches to the trailing arms. Hopefully it'll be effective.
Joel
Classique71
Colac, Victoria
Re: Installing rear swaybar Sun, 24 August 2003 07:46 Go to previous messageGo to next message
Try it and see !
blackRA28
adelaide
Re: Installing rear swaybar Sun, 24 August 2003 09:28 Go to previous messageGo to next message
Hey Joel,
I am in the same situation as you, ive got a selby rear bar that attaches itself to the trailing arms with the d bushes, but mine came cheaper because was missing the second set of d mount pairs.. Im making them up at work placement tho so its all good, but then ive got to mount it.
Im not sure about how far apart to mount them either, but there are signs of wear on the bar i got in two distinct sorta spots so im going to have to guess on where to attach it from them..
Probably about 15-20mm gap in between, mabye someone more knowledgable could say for sure??
I saw your other post, doesnt that just suck when you buy fresh parts/bushes and they dont fit in properly, that was the same story with my front Noltec swaybar mount link bushes.. The new bushings were way too thick compared to the old four off each bolt! the new four Noltec ones didnt even fit on the bolt with those metal tubes! Havent even finished that proplem yet, just gona cut the bushes down thinner tho.. Confused
In regards to your problem, i guess you may have to just find a new bolt that does fit, but be wary not to alter vital suspension geometry when changing stuff.. (im no genius tho, this is just what ive heard)
When ive had the chance to make up these D mounts and get new bushes too, i'll give you an update ! Im a bit wary on doing the new bushings all round in the rear now .. Rolling Eyes (more headf*cks..)
Hope it goes well,
________________
blackRA28
gold28
Madrid - Spain
Re: Installing rear swaybar Mon, 25 August 2003 03:18 Go to previous messageGo to next message
G'day Joel, thats a pretty looking anti-roll bar ya got there.
I have onlt ever used a chassis mounted bar bafore, so I may be way off here, but from what I can see from your photo, It wouldn't make any difference where you bolted them up.
My reasoning for this is as follows.
This set up rely's upon the relative angle of the lower control arms to generate the twist in the bar. This means that where ever you bolt the thing on, you will be getting the same amount of twist because the lower control arms are moving the same amount.
Where this differs from the chassis mounted type is that by changing the arm length, or distance from chassis pick up to transverse part of the bar, you change the moment acting on the bar. Ie shorter arm = stiffer bar.
My advice is get the mounts as far apart as you can securely get them. This will lower the loads on the bushes and reduce wear. Have the forward one with say 5-10mm of the bar extending past the front of the mount and the back of the rear mount next to the start of the bend. That way, everything is sitting easily and not preloading the bushes and the forward mount has enough safety so it won't come loose.
Jason
Re: Installing rear swaybar Mon, 25 August 2003 03:27 Go to previous messageGo to next message
Hi Joel
That one is the same as the one i just pulled of my 23, make it so the bar is just furward enough so you can get a trollie jack under the centre of the diff housing as for the d clamps as far as you can get them apart leaving about 20-30mm at the end of the swaw bar.
Re: Installing rear swaybar Mon, 25 August 2003 04:12 Go to previous messageGo to next message
Thanks all for your info, i'll finish setting it up tonight and see how she goes Smile
Re: Installing rear swaybar Wed, 27 August 2003 11:51 Go to previous messageGo to next message
Hi all, well finished putting the swaybar on tonight
Here is a pic :
http://members.optusnet.com.au/helenfitz/rearswaybar1.jpg
I had to mount it so the bar sits infront of the diff, do you think this is ok? if I tried to mount it just behind the diff it ran into the bottom of the trailing arm mounts off the diff.
Also, if you look in the pic you can see the mounts are not quite vertical up and down, but are twisted in towards the car. I couldn't seem to do anything about this, the bar isn't wide enough to allow them to sit flat. What do you all think?
Many thanks,
Joel
blackRA28
adelaide
Re: Installing rear swaybar Wed, 27 August 2003 12:40 Go to previous messageGo to next message
Looks great mate, the noltec bushes and matt black bar look cool..
looks sweet all in place like they should have come with..
TurboRA28 wrote on Wed, 27 August 2003 21:21
Hi
This was the same with the rear bar i bought, it is a selby too i think.. It is just slightly too narrow so the arms sit just inside the trailing arms.. and thus the d-mounts are slightly angled.. i think this is okay.
As far as forward or backward positioning, im not sure.. i have these two d mounts with hoops to mount the bar to the diff/axle housing also.. Did you get any of these such mounts at all with your bar/kit? I guess when i put them on mine it will restrict movement of the bar even more..
Peace
gold28
Madrid - Spain
Re: Installing rear swaybar Wed, 27 August 2003 22:48 Go to previous messageGo to next message
Looks great Joel. Should make a big improvement. Give it a hard time and tell us how it goes. You may find that your car has more of an under-steer tendanacy on a steady corner, but I you should have plenty of power to balance that out Very Happy
Fore aft shouldn't make any difference.
I am sure you can appreciate that if the mounts were sitting sideways, the bar would be trying to twist them around the trailing arms, but that angle doesn't look too bad, I wouldn't be worried about it, just make sure the bar doesn't move to either side.
Re: Installing rear swaybar Wed, 27 August 2003 23:10 Go to previous messageGo to next message
BlackRA28 - didn't realise there was mounts to go onto the diff!?
Brought it secondhand so makes it a bit hard to know what should/shouldn't be included.
What are these extra brackets like that go to the diff? Might have to try and hunt down a set.
Anthony - will let you know how it goes when I take it for a spin tomorrow night.
Joel
Bugman
Re: Installing rear swaybar Thu, 28 August 2003 00:00 Go to previous messageGo to next message
yeah my one I have here mounts to the chhssis mount for them arms and has shackles that go round the diff.
blackRA28
adelaide
Re: Installing rear swaybar Thu, 28 August 2003 13:25 Go to previous messageGo to next message
Hey Joel,
i think i have a pic of the diff hoop/D-mounts.... ill post up an address for you to check out, seeing yahoo is too pov to link any pictures..
yeh i got mine 2nd hand and was missing half of everything!!
hehe..
Diff Mount:
http://f1.pg.photos.yahoo.com/ph/fat_tony99/vwp?.d ir=/Rear+Sway-bar+Pics&.dnm=Diff+mount.jpg& ;.view=t
or try:
http://f1.pg.photos.yahoo.com/ph/fat_tony99/lst?.d ir=/Rear+Sway-bar+Pics&.src=ph&.order=& ;.view=t&.done=http%3a//f1.pg.photos.yahoo.com /
______________
BlackRA28
Re: Installing rear swaybar Fri, 29 August 2003 14:01 Go to previous messageGo to next message
Went for a run up the Old Pac tonight and all I can say is WOW!
It has made the biggest difference. Before the Celica was always a challenge to get around corners quickly, now its easy.
Anthony you were right, understeers a bit now but not too bad.
One of the best suspension upgrades i've done so far.
Joel
shinybluesteel
melbourne
Re: Installing rear swaybar Fri, 29 August 2003 14:30 Go to previous messageGo to next message
joel, that swaybar isnt on backwards is it?
most ones that i have seen have the "free" ends near the diff, and the "middle" bit nearer the front of the car.
(EDIT: doing it this way will reduce unsprung weight by a tiny amount too, and if oyu can mount it this way, the "twisting" part of the sway bar should be in line with the chassis mounted pivot point of the lower control arms)
would it fit this way??
if it fits, and it works, then i suppose thats all good,
i suppose it would work either way, but it looks a bit funny to me.
[Updated on: Fri, 29 August 2003 14:40]
ddeane
PNG
Re: Installing rear swaybar Fri, 29 August 2003 23:41 Go to previous messageGo to next message
Well done. The sway bar is fitted correctly - either that or the manufactor's instructions that I have are wrong!
Craig
gold28
Madrid - Spain
Re: Installing rear swaybar Sun, 31 August 2003 21:31 Go to previous message
Great to hear Joel.
I love it when you fiddle with something on your car and can feel the difference.
Speaking of the Old Pacific Highway, did you hear that the East Coast Classic will be running a stage on the highway between Cowan and Brookland. It is on this Wednesday, cars assembling ont he top level of car park, Westfield Hornsby and heading off to Cowan at about 11:30. Apparently it is a bit like Targa Tasmania, with new and old cars entered. Should be a great day.
Previous Topic:RX7 calipers onto AE86.
Next Topic:GA 70/JZA 70 MAP sensor ???
Current Time: Thu Oct 15 10:42:18 UTC 2026
Total time taken to generate the page: 0.0057089328765869 seconds
