Toymods » Tech & Conversions » Crossmember/Chassis spacers
Crossmember/Chassis spacers Sun, 24 August 2003 09:56 Go to next message
Anyone used spacers between the crossmember and chassis rails before?
Any problems doing this?
Bill Sherwood
Brisbane / Gold Coast
Re: Crossmember/Chassis spacers Sun, 24 August 2003 11:58 Go to previous messageGo to next message
Yep, though I haven't driven the car yet.
The Sprinter had to get some for the big 3SGE gen four engine to fit under the bonnet. They're only about 10mm thick so not that big.
The main thing (I expect) to notice is that the front roll centre will be a little higher than what it was before, so I may have to go to 45mm thick RCA's instead of the 30mm ones I have now.
With a slightly higher front roll centre the car will understeer a little more.
Re: Crossmember/Chassis spacers Sun, 24 August 2003 12:05 Go to previous messageGo to next message
Thanks Bill. 10 - 15mm spacers would be perfect for what I want to do! I'm also looking at getting some large spacers made to sort out the roll center problem. Do you know if the RCA's from a sprinter would fit a TA22? If they do i'll get a pair of the 45mm items with you Very Happy
Stefan
Hobart, Tas
Re: Crossmember/Chassis spacers Sun, 24 August 2003 12:28 Go to previous messageGo to next message
Umm... I'm confused: if your roll centre is *higher* than before with these xmemember spacers, and you were going to use RCAs (i assume to compensate lowered for springs), it seems to me you would have to use shorter RCA blocks, not higher ones.
Where am I going wrong? Is it because the lowering the xmember also mucks about with the control arm mounts? Also, I thought a higher roll centre was desirable, putting it closer to the front centre of gravity and decreasing front body roll.
Re: Crossmember/Chassis spacers Sun, 24 August 2003 12:33 Go to previous messageGo to next message
Putting a 10mm spacer between the crossmember and the chassis is like lowering the car 10mm!
Re: Crossmember/Chassis spacers Sun, 24 August 2003 13:09 Go to previous messageGo to next message
Cool1 wrote on Sun, 24 August 2003 22:33
maybe if the crossmember bolts to the top of the chassis rails??? sounds like it is raising the car body off the crossmember, but since the ride height comes from the struts, it will only affect geometry, not ride height....? how will it lower the car??
Re: Crossmember/Chassis spacers Sun, 24 August 2003 13:12 Go to previous messageGo to next message
I didnt mean it was lowering the car Rolling Eyes I meant that like lowering the car it will make the control arms go higher than standard! Which means you will need RCA's to bring them back down!
All clear?
Re: Crossmember/Chassis spacers Sun, 24 August 2003 13:18 Go to previous messageGo to next message
ooooohhhhhhh Embarassed right Rolling Eyes
spent too much time workin on my mums car in the rain last night.. damn FWD cars Mad
clear as... as a really clear thing Very Happy
Bill Sherwood
Re: Crossmember/Chassis spacers Sun, 24 August 2003 23:10 Go to previous messageGo to next message
Bugger!
I made a mistake - It'll LOWER the front roll centre, not raise it.
The effect of that is to make the car understeer a little more on corner entry and oversteer on the exit.
RCA's lift up the front roll centre to get it back to where it should be, in relation to the rear one to keep the handling good.
Stefan
Hobart, Tas
Re: Crossmember/Chassis spacers Mon, 25 August 2003 00:14 Go to previous message
Bill Sherwood wrote on Mon, 25 August 2003 09:10
Bugger!
That's what I meant. If whatever you did lowered the roll centre more, you need bigger RCAs... if it raised the roll centre more, you need smaller ones.
Wow, what I said was actually right. Shit.
(I'm waiting on some 30mm RCA blocks from a celicasupra group buy, hoping it will reduce front body roll and improve the handling further)
Previous Topic:3SGTE- loss of hp.
Next Topic:CT12's are they cermaic or steel.
Current Time: Thu Oct 22 13:57:46 UTC 2026
Total time taken to generate the page: 0.0067079067230225 seconds
