Toymods » Tech & Conversions » Attn: IRA11Y, Re: Brake Upgrade Article
icon1.gif  Attn: IRA11Y, Re: Brake Upgrade Article Thu, 16 May 2002 09:31 Go to next message
Regarding your brake conversion article.
Did you use the GX60 brakes or the MX62?
According to DBA, the size of the MX62 disk is 248 x 18mm where as you quoted 280 x 26mm!
EDIT: changed title to clarify contents Smile
I didnt change the title at all Confused
[Updated on: Mon, 13 October 2003 06:36]
IRA11Y
Club Member
Re: Attn: Michael Seymour Thu, 16 May 2002 22:11 Go to previous messageGo to next message
I used the GX60 disks which are the size quoted
Re: Attn: Michael Seymour Fri, 17 May 2002 07:03 Go to previous messageGo to next message
Thanks mate, Just thought i'd clear that up!
Callifo
Gawler, SA
Re: Attn: Michael Seymour Sat, 11 October 2003 13:25 Go to previous messageGo to next message
Just bringing the article up again.
Want to upgrade the front brakes on my sprinter and was reading through the article and was wondering what I need to change?
Im not quite clear on why the strut needs to be changed? Can the discs, calipers, etc just be swapped over from a cressida?
Sorry, noobie to this Razz
Oh and is there any other toyota which would also serve as a suitable donor as my local U-pullit dont appear to have any cressida? I could buy the parts from another wrecker if I had to but would be more expensive.
[Updated on: Sat, 11 October 2003 13:31]
Re: Attn: Michael Seymour Sat, 11 October 2003 14:43 Go to previous messageGo to next message
From memory those GX60 discs are very similar to some more readily available Tarago discs.....
IRA11Y
Club Member
Re: Attn: Michael Seymour Sun, 12 October 2003 02:13 Go to previous messageGo to next message
I used the whole strut as i deemed it easier to cange a steering arm,suspension components and a brake line compared to fabricating a new plate for the calipers and attempting to get the rotor to fit on the stock axle. I never tried to just swap them over so if you want to try go for it.
making an educated guess the RA60? celica/supra will fit as well, it has similar dimensions to the cressida I believe in terms of the steering arm etc.
Callifo
Gawler, SA
Re: Attn: Michael Seymour Sun, 12 October 2003 11:11 Go to previous messageGo to next message
Ok well might go for changing the whole strut then aswell, dont want to get things fabricated.
Would changing the strut effect the ride height? Plan to keep the stock springs and use those on cressida struts.
Re: Attn: IRA11Y, Re: Brake Upgrade Article Sun, 12 October 2003 14:01 Go to previous messageGo to next message
It's true that the local MX62 cressida only has the 248x18mm brakes.... here in australia we weren't so lucky to get the GA60 cressida with its big brakes.
However, some RA65's, and MA61's have a slightly larger and thicker disc than the MX62, and predominantly the same strut.
Best way to compare - self serve auto wreckers. Pull a coupla struts and do some dummy swaps Smile
sprinterboy4agze
Re: Attn: IRA11Y, Re: Brake Upgrade Article Sun, 12 October 2003 21:33 Go to previous messageGo to next message
can someone direct me to this article? is this a brake upgrade to a sprinter?
Ribbo
Northern Beaches
Re: Attn: IRA11Y, Re: Brake Upgrade Article Sun, 12 October 2003 22:34 Go to previous messageGo to next message
in the menu on your left click on the articles link
Re: Attn: IRA11Y, Re: Brake Upgrade Article Mon, 13 October 2003 03:19 Go to previous messageGo to next message
Toymods is actually a lot more than just an internet forum. We are a car club, a community, and a haven for sharing tech info.
go to http://www.toymods.org.au and have a look at what we do other than just an internet forum Smile
IRA11Y
Club Member
Re: Attn: IRA11Y, Re: Brake Upgrade Article Mon, 13 October 2003 06:24 Go to previous messageGo to next message
yes it may alter your ride and also your shock absorber working lengths.
you will need to measure the two struts to determine the lengths and either adjust your spring for ride hight and/or change the shock to a shorter stroke (if the replacement is longer) or cut and shorten the top of the new strut to the correct length.
either way its all pretty simple stuff
wilbo666
Re: Attn: IRA11Y, Re: Brake Upgrade Article Thu, 23 October 2003 04:39 Go to previous messageGo to next message
ok, time to revive a long dead thread!
Where did you get you ga60 struts (if you got them) and how much were they! Can you think of a better upgrade for a mx62 cressida?
wilbo
IRA11Y
Club Member
Re: Attn: IRA11Y, Re: Brake Upgrade Article Thu, 23 October 2003 06:25 Go to previous messageGo to next message
I chanced on them at a now closed wreckers, the car was an import and they are not readily available in OZ. maybe a JZX soarer would be the next best option, im sure youd find a set at an importers if you tried
pannelvan_screema
Campbelltown, NSW
Re: Attn: IRA11Y, Re: Brake Upgrade Article Thu, 23 October 2003 13:34 Go to previous messageGo to next message
Hey guys i have done this upgrade (MX-62) onto a AE-71. I did what it says on the tech article, swapped the whole strut put AE-71 springs+stut tops on ST141 steering arms ADJ strut tops for fine tuning. It would have to be the best bang for buck thing i have done. $60 a side for struts complete $10 for steering arms
If u want any info just ask me
CHEERS
wilbo666
Re: Attn: IRA11Y, Re: Brake Upgrade Article Fri, 24 October 2003 02:49 Go to previous message
pannelvan_screema wrote on Thu, 23 October 2003 23:34
CHEERS
hehe I was actually looking into better brakes for a MX62! Laughing
Previous Topic:7A-FE tachometer installation
Next Topic:sprinter diff in a ke70
Current Time: Fri Nov 20 06:59:20 UTC 2026
Total time taken to generate the page: 0.029232025146484 seconds
