Toymods » Tech & Conversions » 4AGE into a KE30 crossmember mounts
roadrunner
Hornsby, Sydney
4AGE into a KE30 crossmember mounts Sun, 24 August 2003 12:22 Go to next message
I know the ae71 cross member bolts into th ke70 but does it bolt into a ke30 or will i have to weld in new mounts?
cheers roadrunner
Re: 4AGE into a KE30 crossmember mounts Sun, 24 August 2003 13:11 Go to previous messageGo to next message
Ke70 cross member is totally different to all previous corollas. the chassis rails are wider and it is of a different shape. it can be made to fit, but you will need to modify the crossmember to bolt up to the rails.
it would be so much easier to just get some 4 or 5mm thick steel and weld up new mounts..... then you can sit the engine where you want (ie low). unless you really want the rack and pinion steering of the 70?
demuire
Ipswich
Re: 4AGE into a KE30 crossmember mounts Sun, 24 August 2003 21:07 Go to previous message
I've been told it's easiest to use the AE71 engine mounts, cut them off the crossmember and then weld them onto your KE30 crossmember. This is what I'll be attempting to do with mine.
Previous Topic:Pitman Arm Removal
Next Topic:rack/pin steering from ae92 too ae82.
Current Time: Wed Oct 21 02:54:26 UTC 2026
Total time taken to generate the page: 0.0051090717315674 seconds
