Toymods » Tech & Conversions » fuel regulator 3rd gen 1GGTE where to buy
Les
fuel regulator 3rd gen 1GGTE where to buy Mon, 25 August 2003 22:44 Go to next message
anyone know where i can get one of these from ?
SSS automotive ??
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Tue, 26 August 2003 09:37 Go to previous messageGo to next message
bump
gold28
Madrid - Spain
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 03:31 Go to previous messageGo to next message
Thats where I would go.
You could probably get aftermarket adjustable ones to suit
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 06:35 Go to previous messageGo to next message
aftermarket = expansivvvvve ? Shocked
gold28
Madrid - Spain
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 06:39 Go to previous messageGo to next message
Or grab one from a wrecker that runs at the right pressure. I don't think it has to be a 1G regulator.
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 07:17 Go to previous messageGo to next message
ahhh, at the right pressure... and how am i gonna get one that will run the "right pressure" dude !??!
and where can i find wrecked 1G's ?!??!
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 08:52 Go to previous messageGo to next message
Malpassi adjustable for EFI, about $150-170
rising rate is about $170-190
cheapish and reliable.. you'd prolly want the non-rising rate tho...
i have a VL commondore one. not a turbo, but that might be a good place to look. they are external and hook up with hoses, and will be about the same pressure.... aren't most injectors about 250kpa?
The Bruster
UK
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 10:55 Go to previous messageGo to next message
TRD do an adjustable one Smile
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 12:51 Go to previous messageGo to next message
my issue is that with 2 fuel pumps running, the car runs fcking rich... will the fuel reg solve my probs (whilst using the stock computer ?
Bugman
Re: fuel regulator 3rd gen 1GGTE where to buy Wed, 27 August 2003 23:49 Go to previous messageGo to next message
les, first hook up a fuel pressure guage and find out whats happeneing.
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 00:14 Go to previous messageGo to next message
Les,
I'd probably look into the adjustable Malpassi one. That way you could try to bring the fuel pressure down to where the stock one thinks it should be.
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 00:51 Go to previous messageGo to next message
Bugman wrote on Thu, 28 August 2003 09:49
yeh will be doing that Smiley =
but i am telling ya.. its flooding in there
how much are they Nathan ??
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 00:54 Go to previous messageGo to next message
Look 5 posts up dude.
Bugman
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 01:02 Go to previous messageGo to next message
les, if it runs ok with the one pump i'd be guessing that the standard fuel reg cannot flow enough hence the pressure could be high, only soution is to remove it from the circuit and install an aftermarket reg that can flow a larger volume.
Bugman
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 01:06 Go to previous messageGo to next message
I have gotta ask the question though..
why do you now have two pump running in series? was fueling a problem before? this will not solve any surging problems if you had any. Did you have any problems with the fueling for the motor with just running the one pump? it seems like you re just causing yourself more problems than it is worth.
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 02:21 Go to previous messageGo to next message
well THATS WHAT I THINK !!!!!!!!!!!!!!!!
my mechanic just though while the car is off the road, might as well do it ...
he believes it runs lean on boost
gold28
Madrid - Spain
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 02:32 Go to previous messageGo to next message
You must have a special one, every other one I have seen runs really rich on boooooost. Mine hits 10.
Bugman
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 03:37 Go to previous messageGo to next message
a standard toyota ecu running lean on BOOOST.. doubt it.. but once again.. fit a fuel pressure guage and find out if you are loosing pressure
Bugman
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 03:41 Go to previous messageGo to next message
or better yet, put it on the dyno and check out your a/f ratio and you shoud put down abou 120ish rwKW so it's a good tool to see how your motor is going.
Les
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 04:22 Go to previous messageGo to next message
goddam - u guys are losing me - im just the apprentice mechanic... my mates the expert... i'll let him read and see what he says Smiley = !!!
gold28
Madrid - Spain
Re: fuel regulator 3rd gen 1GGTE where to buy Thu, 28 August 2003 04:58 Go to previous message
The standard ECU is supposed to run really rich under boost. Toyota do this as a safety measure to prevent detonation.
If yours is running lean it means that there is a problem somewhere. It may have been the pump but it shounds like you solution has caused more problems.
Previous Topic:SR20 Conversion Options
Next Topic:t50 box
Current Time: Sat Oct 24 16:16:15 UTC 2026
Total time taken to generate the page: 0.0059559345245361 seconds
