Toymods » Tech & Conversions » How do i take strut insert out?
Simon-AE86
Banned user
ADELAIDE - The Drift City
How do i take strut insert out? Mon, 25 August 2003 23:23 Go to next message
Am trying to undo the top nut and the whole tube just turns... Tried using vicegrips to hold it with no luck.
RobST162
Re: How do i take strut insert out? Mon, 25 August 2003 23:50 Go to previous messageGo to next message
I had to go borrow a really large vise Sad
shinybluesteel
melbourne
Re: How do i take strut insert out? Tue, 26 August 2003 00:28 Go to previous messageGo to next message
use a stilton (stilson?) wrench or two, like the kind plumbers use on pipes, a vice might be a good idea.too.
Jason
Re: How do i take strut insert out? Tue, 26 August 2003 00:34 Go to previous messageGo to next message
Is that the nut on the strut top or the nut on the strut ousing thing?
Simon-AE86
Banned user
Re: How do i take strut insert out? Tue, 26 August 2003 00:39 Go to previous messageGo to next message
the top one.
the gland nut i havent touched yet
RobST162
Re: How do i take strut insert out? Tue, 26 August 2003 00:53 Go to previous messageGo to next message
I just thought of this...
theoretically you could attach it back up down the bottom and leave it inserted through its holes up the top (that is reassemble the strut in the car just loosely to stop it from turning) and then loosen the strut nut, and then take it all off down the bottom and up the top, remove the strut, and then finish the nut off since it will be loose ... that only works in certain situations though, but it might work for yours Smile
But I think your problem is that the spring and all turns yeah? heck, you you doing the back or front? my theory only works on the back. I think on the front, the spring etc will want to spin too... Sad
Simon-AE86
Banned user
Re: How do i take strut insert out? Tue, 26 August 2003 01:01 Go to previous messageGo to next message
Im doing the fronts whihc are a coilover with aftermarket pillowbal tops, Trying to undo the nut but the whole shock tube just turns as well. I tried using vice grips on the tube but i cant get a good enough grip. dont really care about stuffing the shock up as they are stuffed anyway
Simon-AE86
Banned user
Simon-AE86
Banned user
Simon-AE86
Banned user
Simon-AE86
Banned user
Re: How do i take strut insert out? Tue, 26 August 2003 01:03 Go to previous messageGo to next message
sorry about the multiple posts. Our server is playing up BIG time today
RobST162
Re: How do i take strut insert out? Tue, 26 August 2003 01:09 Go to previous messageGo to next message
ah I see. So the lower strut doesn't turn, just the inserted rod. hmmm will have to think about this one Smile
Jason
Re: How do i take strut insert out? Tue, 26 August 2003 01:38 Go to previous messageGo to next message
Try a rattle gun thats how i did it last time
Re: How do i take strut insert out? Tue, 26 August 2003 01:46 Go to previous messageGo to next message
This post is probably going to make no sense but here goes...
When I did mine, the strut top fitted onto the strut in a way that they are locked together, its like the strut top where the strut goes in was a D shape and not a 0 shape. So if you can hold the strut top in place then the strut itself cannot turn.
So I put the strut top in the vice which is easy to hold in place and then undid the nut...
Might work for you..
Joel
Simon-AE86
Banned user
Re: How do i take strut insert out? Tue, 26 August 2003 01:50 Go to previous messageGo to next message
yeah i get what u mean mate! but i dont have that or anyway of locking it in place Sad
Re: How do i take strut insert out? Tue, 26 August 2003 02:02 Go to previous messageGo to next message
If no vice, you could always put it back in the car.. At least the top 3 bolts back up in the shock tower so it can't move.
Or you away from car too?
RobST162
Re: How do i take strut insert out? Tue, 26 August 2003 02:16 Go to previous messageGo to next message
I had to put one of mine back in the car to do it, as I didn't have tools to do it otherwise... Confused
Re: How do i take strut insert out? Tue, 26 August 2003 02:41 Go to previous messageGo to next message
Yeah that's what I did as well... I loosened it while it was in the car. The weight of the car on the strut prevented it from turning too easily.
Simon-AE86
Banned user
Re: How do i take strut insert out? Tue, 26 August 2003 04:12 Go to previous messageGo to next message
no luck there either... i thought about this prob before i took them out and even with the weight of the car on them the shock tube turns way too easy
Re: How do i take strut insert out? Tue, 26 August 2003 06:47 Go to previous messageGo to next message
Bring em round here man and we'll stick them in the vice! Its all bananas from there!
Joshstix
Toymods Vice President
Re: How do i take strut insert out? Tue, 26 August 2003 09:06 Go to previous messageGo to next message
The problem is that his strut tops are running spherical bearings not the normal strut tops where they lock the shaft from spinning. The shaft is circular all the way up out of the bearing with this setup.
On my rears there is a allen head drive in the top of the shaft but the front has nothing. What I did for the front ones is to get a 3" or so length of garden hose, split it lenghtways and then wrap this around the shaft. Then I got a set of vice grips and locked them down as hard as possible on hose around the strut shaft and undid the nut. Of course some penetrating lubricant would be handy and you'll probably find that using this method to tighten the strut after you install the new ones will not get rid of all of the rattles.
Re: How do i take strut insert out? Tue, 26 August 2003 09:35 Go to previous messageGo to next message
1)can you grind flats onto the shock rod with an angle grinder or dremel?? then lock the V-grips onto that, .... or get some vice grips with really sharp teeth so it digs in..
2)if you can securely compress the springs (like with 4 compressors) why not cut the whole shock rod off!!! then clamp it in a vice.... a little destructive, but there's not much an angle grinder can't fix Wink
option 1 always works for me....
Simon-AE86
Banned user
Re: How do i take strut insert out? Tue, 26 August 2003 10:31 Go to previous messageGo to next message
thanks for the tips... im going to start getting brutal now Wink
RobST162
Re: How do i take strut insert out? Tue, 26 August 2003 10:33 Go to previous message
hehe, feel free to come get my Stihl chainsaw anytime you feel the urge Smile
Previous Topic:Chaser stats?
Next Topic:motor swap for AE82....any suggestions?
Current Time: Mon Oct 19 08:52:06 UTC 2026
Total time taken to generate the page: 0.05969500541687 seconds
