Toymods » Tech & Conversions » Pulleys
coronamark2
icon5.gif  Pulleys Tue, 26 August 2003 02:24 Go to next message
I want to get rid of the engine fan on my car and replace it with twin thermos(which is another topic all together).
I have seen a ford with chrome pulleys with a big thick arse belt can you change pulleys around whats involved?
They are like the pulleys on supercharged V8s.
it looked sick maaaaaaate
the belt width was about this:
Re: Pulleys Tue, 26 August 2003 02:26 Go to previous messageGo to next message
Why would you want to change pulleys?
Danners
Central Coast, NSW
Re: Pulleys Tue, 26 August 2003 02:28 Go to previous messageGo to next message
haha!
i know exactly what you mean.... the belt is so wide that they actually give you that whirring noise as well
Can't give you any info on it unfortunately.... if you get thermo's though you won't need that belt anymore (just a thought)
thermo's make for less friction... therefore more horsies!
Dan
Re: Pulleys Tue, 26 August 2003 02:39 Go to previous messageGo to next message
Are you talking about gilmer(sp?) drive? Definitely not the sort of thing you'd get just because it looks "sick".
Re: Pulleys Tue, 26 August 2003 02:42 Go to previous messageGo to next message
Of course he will need the belt - what will turn the altenator, water pump and any other accessories?
Yes you can change pulleys, but for your 4M, they will be custom. You will need to take note of the diameters so you dont overspeed the accessories, the machinist will need to index the crank pulley so you can still check the timing, and you need to check that a belt is available in the size you are after. It sounds like a lot of headache to me.
Danners
Central Coast, NSW
Re: Pulleys Tue, 26 August 2003 02:50 Go to previous messageGo to next message
http://www.profixauto.com.au/images/news/forcefed/ images/forcfd1.jpg
is this what you mean? Pic of a gilmer drive belt and gear
coronamark2
Re: Pulleys Tue, 26 August 2003 02:52 Go to previous messageGo to next message
So a metal machinst can do it?
Can the pulley on the engine be changed without pulling the hole thing apart?
So how much power would you gain from going to thermos?
(i dont expect much but..)
coronamark2
and yes thats what i mean?
looks good ay? Very Happy
Re: Pulleys Tue, 26 August 2003 02:54 Go to previous messageGo to next message
It obviously can't be a lot if BMW decided to stick with a conventional fan on its hipo N/A M3 engine.
Re: Pulleys Tue, 26 August 2003 02:55 Go to previous messageGo to next message
mmmm Gilmer drive Smile
often used with superchargers because they are non-slip, like timing belts. they are pricey, wear quicker (cos of the teeth), but they do sound like you have 6/71 hiding under there Wink
they are available for rotaries as well as the ford/holden crowd, but for the expense of three pulleys plus belt?
the stock V or ribbed belt will be fine, especially with fan removal as the fan probably used most power out of the fan, water pump or alt.
but if you want the fooly sik sound Wink it would be very shiny!
ps
http://vpw.com.au/asp/product_page.asp?sub_cat_id= 743&manu_id=
about $330 if you have a V8
coronamark2
Re: Pulleys Tue, 26 August 2003 02:59 Go to previous messageGo to next message
its those crazzsy germans
Hail! Laughing
Re: Pulleys Tue, 26 August 2003 03:11 Go to previous messageGo to next message
CM2, yep a machinist can do it. Just remember each rib on the outer edge of the pulley is a machining manoeuvre and each one of those costs a bit of money. Many ribs equals many bits of money.
rob_RA40
c'town, NSW
Re: Pulleys Tue, 26 August 2003 03:20 Go to previous messageGo to next message
waste of time and money dude... save for a better engine.
coronamark2
Re: Pulleys Tue, 26 August 2003 03:23 Go to previous messageGo to next message
how dare you mock the mighty 4m Very Happy Laughing
Re: Pulleys Tue, 26 August 2003 06:12 Go to previous message
CAPA have the pulleys from that pic.. to go with the Vortech SC.. but $$$
you do get a bit more out of an engine when you take off the fan, but i guess is more noticable on smaller capacity, or bigger fan.....
instaed of thermos, what about a clutched or viscous fan coupling? reduces speed and power loss at high revs....
Previous Topic:Do AE86 steering arms fit on a RA40 strut? --- NEED TO KNOW ASAP
Next Topic:engineer in sydney and how much
Current Time: Thu Oct 22 09:41:55 UTC 2026
Total time taken to generate the page: 0.033969879150391 seconds
