Toymods » Tech & Conversions » stalling 7mgte
89supra
icon11.gif  stalling 7mgte Tue, 26 August 2003 09:42 Go to next message
i ercently bought a 89 supra, iv just bought a pod filter and a bov, the bov is installed and working, the standard air filter is off and im still waiting for the pod filter attachment to be ordered in. the car only stalls when i put the car into neutral when coming to a stop. i think its got something to do with the vacumm pressure. anyone now whats going on????
V8_MA61
Re: stalling 7mgte Tue, 26 August 2003 09:45 Go to previous messageGo to next message
do you have the aircon on? Just happening when you put the clutch in?
My ma61 used to have the same problem...was the a/c not stepping up the idle revs!
[Updated on: Tue, 26 August 2003 09:46]
7M-Brisbane
Re: stalling 7mgte Tue, 26 August 2003 09:47 Go to previous messageGo to next message
BOV's are stupid, and I'm 99% sure this is why your car is stalling. Put the stock one back on (or better, a generic Bosch recirculating one as I had on mine) and your problems will go away...
7M-Brisbane
Re: stalling 7mgte Tue, 26 August 2003 09:49 Go to previous messageGo to next message
Also:
* you're mad for running it with no air filter
* this could have damaged the AFM and could be the reason for it stalling
* a pod filter is not necessary, a K&N drop-in one in the stock airbox with the front opening enlarged is all you'll need.
V8_MA61
Re: stalling 7mgte Tue, 26 August 2003 09:53 Go to previous messageGo to next message
oh - crap man are you running it with no filter! that can potentially mash your engine if any stuffs in your engine bay! I have to agree also...Bovs are for honda and nissan silvia nerds..the big whoosh is in fashion for them!
7M-Brisbane
Re: stalling 7mgte Tue, 26 August 2003 10:31 Go to previous messageGo to next message
Being Air Flow Metered the ECU will not be able to compensate for an externally venting valve. If you want to fit a shiny one, make sure it recirculates. If you have a pod filter or a K&N & modified airbox as I described then a recirculatingone will make enough noise to make you look like a wanker if you want to.
89supra
Re: stalling 7mgte Tue, 26 August 2003 14:40 Go to previous messageGo to next message
the car was stalling before the bov went on so it cant be that. its not the a/c, because i have already tried that. the car only stalls when the cluch is released and the gear is in neutral. it doesnt do it every time, just every now and then.
yeah, im going for the wank affect, its my first turbo car, and i love it.
thanks people
ill keep you informed
celicaboy_2000
Lismore, NSW
Re: stalling 7mgte Wed, 27 August 2003 08:47 Go to previous message
What BOV came off it? It has to be venting back into the pipe between the turbo and the AFM, I have had this problem and Iwas quite pissed of (I enjoyed the sound of it blowing out into the atmosphere). Another thing to check is for air leaks, check every pipe. Check that the plug is connected to the AFM. Also maybe source another AFM and try that... Good luck. Post how you go....
Previous Topic:Engine swap .......need some help
Next Topic:wiring people?
Current Time: Wed Oct 28 08:12:13 UTC 2026
Total time taken to generate the page: 0.0095808506011963 seconds
