Toymods » Tech & Conversions » Decent NA rebuild
Shaun
Nelson NZ
Decent NA rebuild Tue, 26 August 2003 09:54 Go to next message
Ok i am still deciding on what to do with my 18rgeu if i was to do a na rebuild i was thinking of dumping the injection (sorry guys not a big fan of all those wires) for twin side drafts, new pistons with larger dome, shaving head and block slightly, nice big cams, bottom end rebuild, port and polish on the head and some dirty big flows. If well done what sort of hp would i be looking at and is lighting the flywheel a good idea if so how much keeping in mind this engine is going into a ute.
Thanks alot guys
Re: Decent NA rebuild Tue, 26 August 2003 10:55 Go to previous messageGo to next message
It depends on a lot of things, but the engine you describe should be good for somewhere between 180hp (barely streetable) and 200hp (not streetable at all). You'd be insane not to use EFI on a street-driven car; it makes a huge difference to overall drivability, and the wiring issue is nothing to worry about if you're using an aftermarket ECU.
Shaun
Nelson NZ
icon5.gif  Re: Decent NA rebuild Tue, 26 August 2003 11:02 Go to previous messageGo to next message
what do you mean by barley streetable and not streetable?
Thanks for the help anyhows
Re: Decent NA rebuild Tue, 26 August 2003 12:59 Go to previous messageGo to next message
As in, it will have no power below 6000rpm, it will idle at 1500rpm, and it will drink fuel like a V8. Fine for the track, but not the sort of thing you want on the street!
Re: Decent NA rebuild Tue, 26 August 2003 13:26 Go to previous message
Shaun wrote on Tue, 26 August 2003 19:54
Thanks alot guys
Run it std and with injection. Do nothing to your flywheel - lightening a cast iron flywheel is unsafe. Big cams will kill low end performance and you'll break rings with high compression if you really load up your ute.
Previous Topic:has anyone put an r154 into a ma61?
Next Topic:bent valves
Current Time: Sun Oct 18 02:53:05 UTC 2026
Total time taken to generate the page: 0.046797037124634 seconds
