Toymods » Tech & Conversions » 4AGE Extractors 4-2-1 vs 4-1 ?
Necros
4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 02:28 Go to next message
Hey Ppls,
As the topic says... Im about to buy some extractors for my ae86 and im wondering what is the difference between the two sorts?
Is the 4-2-1 design worth another $40? Is there any performace gains?
rob_RA40
c'town, NSW
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 02:42 Go to previous messageGo to next message
go 4-2-1
google around theres a shite load of info on the net that talk about the adv/disadv of 4-2-1 and adv/disadv of 4-1.
Dodgy_Haro
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 03:39 Go to previous messageGo to next message
I doubt that a 4-2-1 offers much performance gain over a 4-1 -> what it'd offer you is better driveability around town.
The 4-1 set is meant for high RPM's - you'll find that your car might be doughy in the lower RPM's if you go with these.
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 04:02 Go to previous messageGo to next message
yup, exactly.
4-1 needs high gas velocity to get it working efficiently, and also works in a narrower rev range.
4-2-1 works from medium to high gas velocities, and can have a much broader range of rpm.
it really depends on how it is tuned by the length on each pipe (for pulse reflection) and diameter (for velocity). both need to be right to get the most out of it.
aren't 4AGE stock manifold good already?? i keep hearing rumours that there is little benefit to be gained by going to extractors?
anyone?
kayot1k
icon5.gif  Re: 4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 07:34 Go to previous messageGo to next message
i got werd from the guy who installed my exhaust that buying a new exhaust manifold was expensive and not worth the little gain.
he mentioned a 2 percent increase in power.
which is not worth 400 bucks for new genie extractors he was quoting.
natez
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 08:05 Go to previous messageGo to next message
I'm quite sure necro's is putting the 4age into his RWD Sprinter, and needing some RWD 4age exhaust manifold... so he is getting extractors... not sure if the FWD exhaust manifold is fine for a RWD AE86 4age application
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Wed, 27 August 2003 10:25 Go to previous messageGo to next message
i think that the reference to stock exhaust manifolds was inferring them being in a RWD config.
biased99
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Thu, 28 August 2003 01:07 Go to previous messageGo to next message
natez wrote on Wed, 27 August 2003 18:05
No, the stock FWD manifold won't work for a RWD setup, as it directs the exhaust under the engine...
In my case, we had a set of 4-2-1 headers made up and a full 2.5" system fabricated. Whilst, on the face of it, people may think this a little big for an NA 1600, when the restriction of the cat, plus muffler and resonator, is taken into account, it actually works out quite well.
jazae86
Re: 4AGE Extractors 4-2-1 vs 4-1 ? Thu, 28 August 2003 10:30 Go to previous message
I have run both the stock AE86 4ag extractors and a set of Stewart Wilkins motorsport 4-2-1 extractors and I would say they are much of a much-ness.
Factroy for torque (little more in the bottom end) and the extractors for the higher rpm power (revs cleaner up top).
I think the bottom line will dictate your choice as you will gain nor lose much either way.
http://www.swmotorsport.com/home.htm
For the 250 i paid for the extrtactors I cannot complain.
Jaz
Previous Topic:1G-GTE Dizzy installation!
Next Topic:rack & pinion steering
Current Time: Thu Nov 19 16:00:16 UTC 2026
Total time taken to generate the page: 0.0056838989257812 seconds
