Toymods » Tech & Conversions » 1G-GTE Valve Stem Seals
gold28
Madrid - Spain
1G-GTE Valve Stem Seals Wed, 27 August 2003 03:37 Go to next message
Anybody replaced these before. Can you get to them without taking the head off?
It doesn't concerne me too much but if it just required removing the cams and valve springs, it's not too much on an ask. I don't fancy taking the head off though.
Re: 1G-GTE Valve Stem Seals Wed, 27 August 2003 12:58 Go to previous messageGo to next message
um ... to remove valves & springs you gotta pull the head off ... valve-spring compressor has to press on head of valve (currently out of sight) as well as springs retainer.
TA22-3SGTE
MACKAY
Re: 1G-GTE Valve Stem Seals Wed, 27 August 2003 13:08 Go to previous messageGo to next message
I made a tool up to change the seals on my 3SGTE without removing the head ,Also make up a air adaptor to screw into the plug hole and sit the piston at TDC on the one your working , Took a couple of hours making the tool but was still quicker and cheaper than removing the head .
Trevor
gold28
Madrid - Spain
Re: 1G-GTE Valve Stem Seals Wed, 27 August 2003 22:58 Go to previous messageGo to next message
My thinking exactly trevor.
Some seals are put in on the collar side of the valve and some on the valve side. If they are on the collar side, I can change them without removing the head. You just need to take the spring off and make sure the valve don't drop into the cylinder.
If they go in from the bottom, I have to remove the head regardless. I am keeping my fingers crossed.
Bugman
Re: 1G-GTE Valve Stem Seals Wed, 27 August 2003 23:40 Go to previous messageGo to next message
well anythony, if you manage to work out a way to do it without removing the head and wanna make some extra $$ I would be glad to hve my ones changed too.
TA22-3SGTE
MACKAY
Re: 1G-GTE Valve Stem Seals Thu, 28 August 2003 13:09 Go to previous messageGo to next message
All stem seals go in from the top .
Re: 1G-GTE Valve Stem Seals Thu, 28 August 2003 13:13 Go to previous messageGo to next message
tho - if the stem seals are stuffed, then it's possible (or perhaps likely?) that the valve guides, or seats, or even stems are also worn - would be a PITA if after all that work using the neato tool that you gotta pull the head anyway?
Tho i gotta admit that pulling the head wastes a box of gaskets - so if you're going to do brain surgery, you may as well fix every other head problem you've been trying to ignore...
gold28
Madrid - Spain
Re: 1G-GTE Valve Stem Seals Thu, 28 August 2003 23:35 Go to previous message
Other than a little puf of smoke on start up my engine is good. I can cope with that but if it can be fixed without disturbing everything I don't mind spending a day on it.
Previous Topic:leaning out ae86
Next Topic:Blow thru carby turbo
Current Time: Thu Oct 29 11:19:23 UTC 2026
Total time taken to generate the page: 0.0042850971221924 seconds
