Toymods » Tech & Conversions » Difference between 20valve Auto and 20 Valve Manuel
20valve69corona
Difference between 20valve Auto and 20 Valve Manuel Wed, 27 August 2003 05:48 Go to next message
Hi All,
Quick question,Is there any difference between a 20valve with an auto box and a 20valve with a manuel box.
Is there any difference with the engine or is it just the box.
regards
Will
coronamark2
Re: Difference between 20valve Auto and 20 Valve Manuel Wed, 27 August 2003 06:00 Go to previous messageGo to next message
yes there is the auto box is shit.
there would be no differnce in the engine itself
20valve69corona
Re: Difference between 20valve Auto and 20 Valve Manuel Wed, 27 August 2003 06:04 Go to previous messageGo to next message
ok thanks.
I only wanted it for the engine.
wilbo666
Re: Difference between 20valve Auto and 20 Valve Manuel Wed, 27 August 2003 06:09 Go to previous messageGo to next message
There may be some difference in the ECU (if it concerns you), not sure might want to check up on that from someone who knows!
But the actual engines them selves should be identical otherwise.
MR. 2
Parramatta
Re: Difference between 20valve Auto and 20 Valve Manuel Wed, 27 August 2003 22:37 Go to previous messageGo to next message
the rev limiter is lower in the auto and wiring it up to a manual car is a pain in the arse.... i lernt this the hard way when i did my conversion i strongly recomend getting a manual ecu and harness
20valve69corona
Re: Difference between 20valve Auto and 20 Valve Manuel Thu, 28 August 2003 01:32 Go to previous message
The reason i was asking is that i can get a 20valve Engine with auto gearbox cheap, no wiring or computer.
So there isn't any difference in engines just the wiring and computer.
Will
Previous Topic:engine swap
Next Topic:Cam adjustment w/ existing dowel pins + holes
Current Time: Sat Oct 24 09:57:47 UTC 2026
Total time taken to generate the page: 0.0043230056762695 seconds
