Toymods » Tech & Conversions » emanage on 1jz
robs
nz
emanage on 1jz Wed, 27 August 2003 08:58 Go to next message
Hi every body I have just brought a trust emanage and Eo1 boostcontroller 4 my 1jz supra has anyone had any experience with these things? I have got 440cc injectors frm a rz I have jst got a turbonetis 60-1 to replace my single hf ct26 that i was using as the factory computer was runing very rich . I am wanting to run about 20psi of boost n hopin 4 bout 250+ rwkw fuel system allowing goin 2 go to bosch 044 pump and mite hf injectors to 550-600cc if 440 run out gona change cams to 264 inlet n exhaust will the emanage cope with this input mutch apreciated cheres rob
Chris Davey
sunny coast, qld
Re: emanage on 1jz Wed, 27 August 2003 11:46 Go to previous messageGo to next message
i don't know too much about the emanage sorry as I was trying to get some info on this also. However, the 370cc stock injectors can flow close to 250rwkw so your 440cc should easily cope with the power you are aiming for.
I was told that there is a Soarer in Melbourne running a t78 and auto with an Emanage and they said it is running well. What features does the emanage have?
Re: emanage on 1jz Wed, 27 August 2003 12:54 Go to previous messageGo to next message
with 20psi of boost, assuming you have a good intercooler (which you better if that's your boost aim), you should be well over 250rwkw!
mine was cranking 185 with stock cooler, stock turbos, and 14psi.
robs
nz
Re: emanage on 1jz Thu, 28 August 2003 08:03 Go to previous message
the emanage looks real good on paper its a piggy back type computer that intercepts the outputs to alter timing and fuel it has 16*16 mapping resolution can compensate 4 lrg injectors plus has capacity to controll extra injectors it also has idle stabalizeation 4 big cams n turbos ect it can also be tuned and offers data loging via the Eo1 boost controller it sounded like the syrup to me from what Ive read and been told jst hopin some one would hav some 1st hand experience. yeah I have good big tube n fin intercooler does any one know what the auto trans will handle n rwkw with a big oil cooler a340e
Previous Topic:rack & pinion steering
Next Topic:1G-GTE Internals and Cams
Current Time: Thu Nov 19 15:33:31 UTC 2026
Total time taken to generate the page: 0.0050978660583496 seconds
