Toymods » Tech & Conversions » Blow thru carby turbo
blacks
Blow thru carby turbo Wed, 27 August 2003 10:43 Go to next message
I was wondering if any one can help me with a blow thru turbo setup. I already have an high pressure electric fuel pump and a rising rate fuel pressure regulator. I am now tring to decide what carby to use, I`ve heard su's are good is this true? I've also heard about boost boxes for the carbys to stop them from leaking, will this work?
shinybluesteel
melbourne
Re: Blow thru carby turbo Wed, 27 August 2003 11:07 Go to previous messageGo to next message
SUs are good because they are easily adjustable, but you will need to jet (and choke?) it to get it right. you know why you need the rising rate fuel pressure reg?
i would suggest using a cheapass EFI system, or just using a suck through carby.
read some old turbo books, i found turbocharging and supercharging by allan allard to be pretty good.
roger
Re: Blow thru carby turbo Thu, 28 August 2003 00:37 Go to previous messageGo to next message
What about a mazda 626 turbo carby. Carby already setup for a 2litre turbo. comes with a nice inlet pipe fitted.
Re: Blow thru carby turbo Thu, 28 August 2003 13:06 Go to previous messageGo to next message
what about suck-thru carb?
mine uses a Zenith CD, but you could also use webber?
(see car site below for example of suck-thru)
saves having to find a rare carbi
blacks
Re: Blow thru carby turbo Thu, 28 August 2003 23:28 Go to previous message
What model 626 had the carby turbo in it. What are the chances of finding one. Could I just use it with an adapter plate, the jetting would already be suitable?
Previous Topic:1G-GTE Valve Stem Seals
Next Topic:90 degree elbows?
Current Time: Thu Oct 29 11:19:31 UTC 2026
Total time taken to generate the page: 0.0046241283416748 seconds
