Toymods » Tech & Conversions » 1G-GTE Dizzy installation!
The Bruster
UK
1G-GTE Dizzy installation! Wed, 27 August 2003 11:07 Go to next message
Hi guys.... Pulled out the dizzy to get access to turbo no. 1 just wondering what the procedure is foor getting it back in on the correct alignment!!!!
Thanks!
The Bruster
UK
Re: 1G-GTE Dizzy installation! Thu, 28 August 2003 00:58 Go to previous messageGo to next message
anyone?
plllleeeeeeaaaaaasssssssseeeeeeeee???????
Re: 1G-GTE Dizzy installation! Thu, 28 August 2003 13:03 Go to previous message
dunno exactly...
but a good starting point is to put engine at TDC for cyl 1,
yo'll probably have to pop rocker cover(s) off to see where the cams are otherwise you might be 180 out,
then try to get dizzi on with rotor pointing before cyl 1 spark-plug (by about whatever the static timing setting is for a 1G is- 10 or 15 or 20 degrees? anyone know?)
then start to tune it properly - assuming it fires up.
Once you get it running again, mark where the rotor is pointing PLUS where the dizzi is on the adjust slot for the next-time you remove the distributor Wink
Previous Topic:Oil Coolers...
Next Topic:4AGE Extractors 4-2-1 vs 4-1 ?
Current Time: Sat Oct 17 10:53:59 UTC 2026
Total time taken to generate the page: 0.089915037155151 seconds
