Toymods » Tech & Conversions » Cam adjustment w/ existing dowel pins + holes
ed_ma61
Lost in the K hole
icon4.gif  Cam adjustment w/ existing dowel pins + holes Wed, 27 August 2003 14:44 Go to next message
just thought id share what i calculated tonight Smile
7m cam gears have 3 dowel pin locations on each of the cams, AND on the cam gears. theyre designed for 1 step of adjustment in each direction away from TDC, whilst maintinaing the timing mark at 12o'clock... the idiots guide to cam degreeing really Smile
this one step allows a total of + and - 1.5deg cam angle adjustment.
however, i sat down tonight and plotted the angular shifts of ALL combinations of dowel pins and holes. and taking into acount the ability to jump teeth with the cam belt, came up with the following posibilities
you can, effectively ADVANCE or RETARD both IN and EX cams by
0.0deg
1.5deg
2.0deg
3.0deg
3.7deg
4.5deg
5.5deg
6.0deg
7.5deg
9.0deg
9.5deg
10.5deg
11.5deg
and on and on and on
ALL using the existing holes (these are cam degrees, NOT crank degrees)
i figured this was a pretty decent level of adjustment, and for most uses, negates the need for fully adjustable cam gears (you can switch the dowel holes pretty easily at the dyno if you wanted to - and then how often do you want to change it??)
ill describe in detail the combinations of dowel and hole arrangments specifically if someone want to do it. otherwise, itll become a tech article on the site one day, and you can find it there... Very Happy
good news none the less...
ed
gabe
Re: Cam adjustment w/ existing dowel pins + holes Wed, 27 August 2003 15:34 Go to previous messageGo to next message
GOD DAMMIT MAN! have you nothing better to do! Cool Razz
On a serious note though I had never given this much thought, and I had no idea you could get that kind of adjustment out of it.
As you said, how often would you want to change it??
Good food for thought Ed.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Cam adjustment w/ existing dowel pins + holes Wed, 27 August 2003 18:26 Go to previous messageGo to next message
I did wonder about the potential of that a while back, but hey, it'll never look as good as a set of nice polished vernier gears! Cool
ed_ma61
Lost in the K hole
Re: Cam adjustment w/ existing dowel pins + holes Thu, 28 August 2003 00:33 Go to previous message
gabe, it took like 20mins to do Rolling Eyes Laughing
for my budget, ill take the adjustability over the $200 shiny bits any day ... Very Happy
ed
Previous Topic:Difference between 20valve Auto and 20 Valve Manuel
Next Topic:loss of power - Whats wrong
Current Time: Mon Oct 26 16:44:13 UTC 2026
Total time taken to generate the page: 0.060928106307983 seconds
