Toymods » Tech & Conversions » engine problem
dukjoon
engine problem Thu, 28 August 2003 01:31 Go to next message
I have had engine on my car overhauled.
They repaired and replaced head, removed and replaced conrod bearings, piston rings, timing belt, VRS kit. They also cleaned up carbon in oil pump.
The job had 20,000km warranty.
I recently had problem with the car and took it to them thinking it's a related problem covered under warranty.
Now they are saying it's a completely different problem not covered under warranty.
They replaced the head, de-carbonised all valves, because excessive carbon on no. 1 cylinder exhaust valve caused valves to not close properly.
The repair bill consisted of distributor cap, head repairs, gaskets plus labour.
Are these two problems really unrelated at all? Could my recent problem have been caused by the mechanics not doing a proper job in the first place?
My thought is that they didn't tune it properly in the first place and I told them that. They say that Honda engines use programmed fuel injection system so they can't change the setting or something like that. Is that true? somehow I can't believe that any engine cannot be tuned at all just because it uses programmed fuel injection
Re: engine problem Thu, 28 August 2003 02:21 Go to previous messageGo to next message
the difference is programmed vs programmable. most factory ECU's are locked, but you can alter fueling my mucking about with sensors.. but that isn't a great way to do it.
as for the repairs? go and get them to document EXACTLY what they did, both first and second time. 'repairs to the head' is not good enough of a description.
what car is it?
dukjoon
Re: engine problem Thu, 28 August 2003 03:05 Go to previous messageGo to next message
oldcorollas wrote on Thu, 28 August 2003 12:21
what car is it?
As for the first job, what i posted here is almost exact words they have on the invoice. as for the second job, they say they repaired and replaced the head.
The car is a Honda Prelude with H22A engine
[Updated on: Thu, 28 August 2003 03:06]
boudan
Re: engine problem Thu, 28 August 2003 03:21 Go to previous message
putting the engine IN your car would be a starter...
a description of the "new" problem would also help... have you check that the mechanic has replaced everything correctly ie all vaccum hoses, etc even the smallest overlooked object can lead to big problems... its always nice to double check wateva the mechanic says they have done to make sure something has been done...
if that makes sense - cant trust 'em as far as you can throw 'em.
Previous Topic:t50 box
Next Topic:gt4 4wd setup in '87 sx celica
Current Time: Sat Oct 24 14:45:32 UTC 2026
Total time taken to generate the page: 0.0051009654998779 seconds
