Toymods » Tech & Conversions » 2JZGTE INJECTORS
1JZ.747
Osama's hideout
2JZGTE INJECTORS Thu, 28 August 2003 04:20 Go to next message
are the capacity of the jap spec 2jzgte injectors the same as the american spec 2jzgte injectors.
and how much bigger are they than standard 1jzgte injectors.
shane
Re: 2JZGTE INJECTORS Thu, 28 August 2003 04:24 Go to previous messageGo to next message
US 2JZ-GTE: 550cc
JDM 2JZ-GTE: 440cc
1JZ-GTE: 340cc
1JZ.747
Osama's hideout
Re: 2JZGTE INJECTORS Thu, 28 August 2003 04:27 Go to previous messageGo to next message
thanks norbie.
next question, who has some they may want to off load soon.
Danish
Re: 2JZGTE INJECTORS Thu, 28 August 2003 05:01 Go to previous messageGo to next message
Why are the US injctors alot bigger?
Re: 2JZGTE INJECTORS Thu, 28 August 2003 05:43 Go to previous messageGo to next message
US-spec 2JZ's are significantly different to JDM 2JZ's. The turbos have steel wheels instead of ceramic and they flow a lot more. The engine management is completetly different (AFM vs MAP). And as mentioned, the injectors are larger. Factory output for US-spec 2JZ's is 320hp, as opposed to 280hp for JDM versions, so that would explain the larger injectors.
wastegate
Gold Coast
Because they made more horsepower.
Visit here to learn more about the JDM vs USDM 2J http://mkiv.supras.org.nz/specs.htm
Grant
Newcastle, NSW, Australia
Re: 2JZGTE INJECTORS Thu, 28 August 2003 06:14 Go to previous message
US spec injectors also need an injector resistor to be run on a 1J ecu as they are low impedence.
Anyway, I have a set if your interested Shane. I also have some information on the reason your fuel gauge doesn't work too.
Grant
Previous Topic:Advice on rebuild 100Kw 4AGE
Next Topic:URGENT - Need place in SE Syd which has lathe / skim 1mm off a pulley.
Current Time: Thu Nov 19 14:00:05 UTC 2026
Total time taken to generate the page: 0.0054018497467041 seconds
