Classifieds » Miscellaneous » FS: TA22 Stabiliser Bars
SeptemberSquallIndustries
FS: TA22 Stabiliser Bars Thu, 28 August 2003 14:33 Go to next message
Heavy Duty stabiliser bars for TA22 Celica. Fitted when the car was acquired, potentially Selby bars, but not sure of this.
Front and Rear available.
In Melbourne.
$75 each.
Michael on 0401 912 279.
roadrunner
Hornsby, Sydney
Re: FS: TA22 Stabiliser Bars Fri, 29 August 2003 04:28 Go to previous messageGo to next message
How thick are they? do they come with drop links brackets bushes etc? How much for both?
Re: FS: TA22 Stabiliser Bars Fri, 29 August 2003 04:59 Go to previous messageGo to next message
1. I'm not sure how thick they are, but can find out if this information is important.
2. All brackets and bushes as currently fitted will be included.
3. $75 + $75 = $150 Wink
4. You're in Sydney, and I'm in Melbourne, you realise...?
KING_22
Oakleigh, Melbourne
Re: FS: TA22 Stabiliser Bars Sat, 30 August 2003 08:45 Go to previous messageGo to next message
bottom end right? they are not strut braces are they
Re: FS: TA22 Stabiliser Bars Sat, 30 August 2003 10:22 Go to previous messageGo to next message
Stabiliser bars are roll moderators at the bottom.
Strut braces are flex moderators at the top.
Understand that this analysis is horribly simplistic and intended for the purposes of illustration only.
[Updated on: Wed, 05 May 2004 03:24]
myTA22
Re: FS: TA22 Stabiliser Bars Wed, 10 September 2003 13:56 Go to previous messageGo to next message
Do you mean swaybars? do you still have these? if so how much? and what size are they?
Re: FS: TA22 Stabiliser Bars Wed, 10 September 2003 14:52 Go to previous messageGo to next message
Stabiliser bars / sway bars / roll bars; whatever term you're happy with, that's what they are... =P
The price is in the original post. I don't have diameters on the bars as I lack the appropriate measuring tool.
The front bar is a supplimnentary bar and the rear is fitted to the control arms to address the lack of a standard bar; on this basis I'd expect the roll stiffness (or lack of same) to be much improved after fitting these bars.
Call me on 0401 912 279 if you're still interested.
EVOSTi
cambo
      no
Re: FS: TA22 Stabiliser Bars Thu, 11 September 2003 11:01 Go to previous messageGo to next message
youd expect? have you driven this car or do you just mean its the only ta22 youve driven?
Classique71
Colac, Victoria
Re: FS: TA22 Stabiliser Bars Thu, 11 September 2003 11:46 Go to previous messageGo to next message
EVo STi - from my own experiences with My ta22 - that had the heavier duty sway bars fitted front and rear - they make a VCAST improvement in the way the car handles - especially in the rear .. having the one on the back really makes the tail of the car more controllable.
For anyone - these bars are a Definate buy if you want your ta22 to handle like it should - believe me for 150 bucks - you cant go wrong !
They are extremely easy to fit as well!
PS : theres no aftermarket strut brace for ta22's that i know of .. They are usually custom made jobbies - but relatively eassy for an engineer to construct ..
Re: FS: TA22 Stabiliser Bars Thu, 11 September 2003 12:05 Go to previous messageGo to next message
EVOSTi wrote on Thu, 11 September 2003 21:01
These bars were fitted to the car when I bought it. A brief road test revealed a degree of slop and play in the suspension. A professional steering/suspension inspection identifies the following issues;
Tie Rod End Inner Left - Fail
Tie Rod End Inner Right - Fail
Tie Rod End Outer Left - Fail
Tie Rod End Outer Right - Fail
Radius rod bushes - L&R - Fail
Front Struts L&R - Fail, completely worthless
Lower ball joints - L&R - Fail
Idler arm - Fail, bushes worn, bearings shot, replacement reqd.
Pitman arm - Fail, bushes worn, bearings shott, replacement reqd.
Front Coil Springs L&R - Pass
Rear upper trailing arms L&R - Fail, bushes *unbonded*
Rear lower trailing arms L&R - Fail, bushes *unbonded*
Sector Shaft / Steering Box - Fail, excessive play
Rear dampers L&R - Fail, completely shot
Rear Coil Springs L&R - Pass
Panhard Rod to Diff bush - Fail
Panhard Rod to Chassis bush - Fail
Fortunately there's no damage, just wear; as such, she's recoverable, and when I'm done rekitting every perishable component under the car she'll literally be better than new.
The point is I presume the swaybars, as aftermarket items, will make a significant improvement. I don't have the ability to make an objective analysis, though, because the condition of the car's underpinnings hasn't established a very good benchmark/basis for comparison.
=P
Re: FS: TA22 Stabiliser Bars Thu, 11 September 2003 12:14 Go to previous message
On a more positive note, I've now settled on a shock absorber choice, lined up the first of my urethane bush sets and received my Whiteline adjustable panhard rod today...
[Updated on: Thu, 11 September 2003 12:32]
Previous Topic: rover 3.5 conversion for hilux: SOLD
Next Topic:RA28 interior
Current Time: Sat Nov 21 03:16:31 UTC 2026
Total time taken to generate the page: 0.005518913269043 seconds
