Toymods » Tech & Conversions » urgent!! - O-rings for 3tgte
bootheman
in a box
urgent!! - O-rings for 3tgte Thu, 28 August 2003 14:47 Go to next message
my projects about 2min away from being finished...
O-ring on one of the injecters is leaking... were can i get one asap? or what other injectors or engines have the same parts.
bootheman
in a box
Re: urgent!! - O-rings for 3tgte Thu, 28 August 2003 14:49 Go to previous messageGo to next message
as in the seal around the injector/engine. almost like a rubber washer. they seamed to have rotted
Re: urgent!! - O-rings for 3tgte Thu, 28 August 2003 23:00 Go to previous messageGo to next message
I just got mine from AutoPro. They had a box of all different sizes and matched some up to fit.
Otherwise, anywhere that cleans/services injectors should be able to supply you with them.
Regards,
Joel
Re: urgent!! - O-rings for 3tgte Fri, 29 August 2003 01:10 Go to previous messageGo to next message
Most Toyota's use exactly the same O-rings, and in fact lots of other Japanese cars are the same as well. Any auto parts store should be able to sell you what you need. If they ask for a specific model, tell them you want O-rings for a 22R-E engine (1985 Celica).
Re: urgent!! - O-rings for 3tgte Fri, 29 August 2003 01:18 Go to previous message
if they are just plain o-rings (ie black ones or orangey ones) then any bearing shop will have them for a few cents each. buy a bunch while you are there. the orange ones have slightly higher temp rating and will last longer (usually called Viton) but are more costly and not always on shelf...
ps, if you are in sydney, eastern suburbs, Hooper Bearings on botany road is great!!!! but any CBC, ABC, ABCDEFG Wink type bearing place will be fine.
Previous Topic:T50 ta22 heavy duty
Next Topic:turboing 18rgeu
Current Time: Mon Oct 26 05:04:14 UTC 2026
Total time taken to generate the page: 0.015064001083374 seconds
