Toymods » General Car Talk » 4AGZE part No.s and Acid Dipping???
Rex_Kelway
4AGZE part No.s and Acid Dipping??? Thu, 11 July 2002 13:27 Go to next message
(1) Are many of the 4A series of engine parts the same across the range? (I.E. Is a 4AGE head gasket suitable for 4AGZE.)
Specifically the following:
- 4AGZE head gasket
- Cam Belt
- Head bolts
Apparently a Head cannot be bolted back with the original bolts (something about stretch or whatever) Confirmation???
And where to buy all this gear, can they be picked up from Roccas etc?
(2) Acid Dip or Degreaser up the Wazoo?, Apparently Acid dipping will also remove any oxidisation?
(3) The block, having no head to keep shit out of it has some specks of junk in the bores. So while the engine is in pieces, should one pull it right down and give it a thorogh clean?
Shall post some pics on the morrow so you can see better than not at all.
[Updated on: Thu, 11 July 2002 13:29]
Bill Sherwood
Brisbane / Gold Coast
Re: 4AGZE part No.s and Acid Dipping??? Thu, 11 July 2002 13:39 Go to previous messageGo to next message
Yeah, a lot of parts can be swapped around no probs at all.
I re-use head bolts a few times before replacing.
The cam belt is the same.
Can't see why the head gasket would be any different at all.
For most parts, I buy that really cheap $2 a can degreaser stuff and just hose it on. The stuff comes out of the cam like a small firehose, so it usually does a good job of cleaning.
For cleaning a head properly though, I take it to the local head shop and get them to tank it.
Juts put a clean rag over the bores to keep the crud from getting in, it should be fine.
Ben Wilson
Re: 4AGZE part No.s and Acid Dipping??? Fri, 12 July 2002 01:53 Go to previous messageGo to next message
I used a genuine Toyota head gasket on my ZE, they are a different part to the NA - Not sure what the actual differences are though.
I got mine from Canberra Toyota.
Any 4AG cam belt will do and you can get them at any car parts place.
jazae86
Re: 4AGZE part No.s and Acid Dipping??? Fri, 12 July 2002 14:40 Go to previous messageGo to next message
Hey Chris,
Been a while, sorry about no reply to your sms, out drinking I think, *I THINK*.
Anyway, as suggested, use 100Kw head gasket. Only Toyota can supply them. I tried rocca and motor traders but I think either toyota only supplier or cheapest. ~$80. I always use Salisbury Toyota, never CMI. Head bolts were either $8 or 12 apiece.
I have seen the GZE, and am pretty dissapointed that rick split the thing as it makes more trouble. I think the valves and retainers are all in there, so you'll only be making work for yourself by stripping it to clean it and risk damaging the valve seals. Just do the best job you can with and put it back together. You will need to re-set the shim's aswell as rick did not number them, so expect some fun. For the block, just clean it the best you can. Considering it's recent storage, stripping the thing would seem over kill.
If you do decide, come over and I can show you just HOW many little bits there are in there, I have a stripped 4ag.
Jaz
Oh, give me a call sometime. I have 3 books that are about putting 4ag's together, including a little Japanese gem called 4AG II (how to build a 4ag without reading a thing. It is crammed full of pic's)
[Updated on: Fri, 12 July 2002 14:42]
Rex_Kelway
Re: 4AGZE part No.s and Acid Dipping??? Tue, 16 July 2002 06:48 Go to previous message
Jaz,
Swish, shall catch up with yer when me gets back from Hotham, on the 27th, if I get back in time and am not totally rooted, may see you on the cruise.
The Engine certainly is in good nick, just a pity about having to put the bastard back together. But atleast it'll give me a chance to have a bash at ye ole 4AGTE build.
Previous Topic:4.5 litre crown is driving...
Next Topic:How to..
Current Time: Wed Oct 14 12:07:07 UTC 2026
Total time taken to generate the page: 0.043633937835693 seconds
