Toymods » Tech & Conversions » using alum as caliper bracket
Simon-AE86
Banned user
ADELAIDE - The Drift City
using alum as caliper bracket Fri, 29 August 2003 00:09 Go to next message
Am using a piece of 12mm thick alum to fabricate a new brake caliper bracket.
before i get too carried away, will this hold up to the task or not? its a bloody thick piece of alum!
the caliper mounting holes are also closer together and further in then the OEM ones.. so there is less chance of stress the further out from the centre hole i go.
any thoughts?
shinybluesteel
melbourne
Re: using alum as caliper bracket Fri, 29 August 2003 01:13 Go to previous messageGo to next message
i think you are allowed to, as long as you helicoil the tapped holes.
do you have much of a choive where to put the mounting holes?
ask dbasteve, although i expect you have already.
Re: using alum as caliper bracket Fri, 29 August 2003 01:15 Go to previous messageGo to next message
I am using a large chunk of aluminium as a caliper bracket. For it to be engineered, it needs to be 6061T6 aluminium (ask to see the certificate and get a photocopy if possible) and any bolts that actually thread into the aluminium MUST be helicoiled.
Simon-AE86
Banned user
Re: using alum as caliper bracket Fri, 29 August 2003 01:27 Go to previous messageGo to next message
well im not sure what type of alum it is. None of the bolts are acctually threading into the alum either.. i have just drilled holes for them to pass through.
JustenGT4
Re: using alum as caliper bracket Fri, 29 August 2003 02:22 Go to previous messageGo to next message
I used CNC's alloy caliper brackets for my brembos onto 330mm rotors. We helicoiled all the threads and haven't had any problems on the street or track. This is pulling up a barge arse GT4 as well Smile
Simon-AE86
Banned user
Re: using alum as caliper bracket Fri, 29 August 2003 02:30 Go to previous messageGo to next message
Well im not CNCing it but rather using a jigsaw, angle grinder and a drill... crude but it will work Smile
Re: using alum as caliper bracket Fri, 29 August 2003 02:32 Go to previous messageGo to next message
it really depends on the alloy. strength of aluminium can vary by an order of magnitude (10x) just by composition and heat treatment... normal alloy sheet is not good enough, as GT said, it should be at least a 6 series alloy, with a T6 heat treatment... or if ya wanna be special, a 7 series...
but all alooy shoul;d be heat treated properly, otherwise it is no better than some random piece of materil you pick up....
better to be safe than sorry....
Cya, Stewart...
Re: using alum as caliper bracket Fri, 29 August 2003 03:43 Go to previous messageGo to next message
Mmmmm....7 series aluminium.....*wipes away Homeresque drool*
Simon-AE86
Banned user
Re: using alum as caliper bracket Fri, 29 August 2003 04:09 Go to previous message
theres a very VERY faint number on this slap of alum. .. it starts with a 6 and is about 5 digits long
6 series?
Previous Topic:3 inch EXHAUST
Next Topic:18RG using 22RE EFI Wiring and ECU
Current Time: Sun Oct 25 04:37:26 UTC 2026
Total time taken to generate the page: 0.005033016204834 seconds
