Toymods » Tech & Conversions » 18RG using 22RE EFI Wiring and ECU
RA28midge
Adelaide and Queenstown T...
18RG using 22RE EFI Wiring and ECU Fri, 29 August 2003 03:53 Go to next message
reading through all the threads on this has just confused me.
I am currently using an 18RC points dizzy and standard coil and ballast resistor for carbies, but for EFI...
Can I just wire up the computer to the -ve side of the coil to get the pulse signal for injectors or do I need to get the Ignitor and coil off the RA65? If I get the coil and ignitor do I then also have to run the 22RE dizzy or can I still use the points dizzy?
Do I also need all the vacuum switches that go to the plenum on the 22RE or are they just extra weight for optimum efficiency?
Re: 18RG using 22RE EFI Wiring and ECU Fri, 29 August 2003 03:57 Go to previous messageGo to next message
Yes, you can wire up the IGN circuit to the -ve terminal of the coil; I used to have my 18R-GEU wired up this way and it worked fine. I'd recommend converting to an electronic dizzy though, as I had issues with points bounce at high rpm.
RA28midge
Re: 18RG using 22RE EFI Wiring and ECU Fri, 29 August 2003 04:05 Go to previous message
lovely, that is what I thought you had said previously but wasn't sure.
It might not be ideal, but if it delays spending $200 til after uni is finished then it makes me happy.
Especially since the head is about to cost me $300 on regrinds and welding.
Now I just need to work out these sensors.
[Updated on: Fri, 29 August 2003 04:06]
Previous Topic:using alum as caliper bracket
Next Topic:Short shifter for a 91' camry
Current Time: Sun Oct 25 12:21:39 UTC 2026
Total time taken to generate the page: 0.0039072036743164 seconds
