Toymods » Tech & Conversions » XF tb on 7MGTE
grande91
XF tb on 7MGTE Thu, 11 July 2002 13:50 Go to next message
Hi all.....ne1 had/has an XF tb on a 7mgte??? Up To Something
jza70-mel
Perth WA
Re: XF tb on 7MGTE Fri, 12 July 2002 08:08 Go to previous messageGo to next message
Is the throttle body a major restriction on the 7m-gte? Would the car benefit more from intercooler/piping/increased boost?
I presume that by increasing the size of the throttle body, you would be aiming to increase the plenum size as well.
grande91
Re: XF tb on 7MGTE Fri, 12 July 2002 13:47 Go to previous messageGo to next message
well in this case bigger is better is'nt it? if you compare the two there's some difference alright,....so i guess the OEM tb is a restriction against the XF tb.....the car did benefit from intercooler/piping/increased boost,....i wanted some idea's on the wiring if ne1 knows,..its 4 wires on the 7m, and 3 on the XF one,......cheers.
ed_ma61
Lost in the K hole
Re: XF tb on 7MGTE Fri, 12 July 2002 14:05 Go to previous messageGo to next message
the 3 wire TPS on the xf t/b is archaic analogue. no way its gonna work with the 7m ecu. just junk the XF TPS and modify the 7m TPS onto the t/b.
as for the 65mm t/b being an improvement, sure, as long as its supported by the rest of the induction system.
ed
[Updated on: Fri, 12 July 2002 14:06]
grande91
Re: XF tb on 7MGTE Fri, 12 July 2002 14:11 Go to previous messageGo to next message
Ok no worries i thought there might have been a chance of that...can't blame me for trying....thanks.
Allan
Re: XF tb on 7MGTE Sat, 13 July 2002 00:07 Go to previous message
major plenium mods to make the XF throttle body an effective upgrade Sad
Allan
Previous Topic:Whiteline Kit For AE86
Next Topic:shift kit??
Current Time: Mon Oct 19 18:04:04 UTC 2026
Total time taken to generate the page: 0.003878116607666 seconds
