Classifieds » Miscellaneous » 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices
twincam_ke20
Castlemaine Vic
icon14.gif  86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Sat, 30 August 2003 11:01 Go to next message
hey all.
Got a 86kw (blue top) 4age with UN-CUT wiring loom, will probably suit a rebuild as its done 206.000kms, 85,000km was done by me, and yes it has served me very well.
$300.00 with fwd gearbox, drive shafts, axles, brake set up, struts and uncut loom/ecu.
Also, i have a heap of left over bits from a ae92 gze trueno front cut, everything EXCEPT the MOTOR/GEARBOX/STRUTS/BRAKES/LOOM/ECU/BONNET SCOOP/DRIVE SHAFTS is there
lights
guards
bonnet
fuse boxs
steering linkage
steering wheel
dash
plastic bits and peices
2 air con units
and probable alot more that i have forgotten, ask and i make have one Very Happy
make an offer, it must go
[Updated on: Sat, 30 August 2003 11:36]
Mr*Beach
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Sun, 31 August 2003 01:59 Go to previous messageGo to next message
When the 4age was in ur car was it running ok? No knocks? I want to be able to do a straight swap and not worry about stripping it. Cheers.
~Josh
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Sun, 31 August 2003 02:06 Go to previous messageGo to next message
yeh it ran fine, i must be honest and say tho, its had a hard life with me, reved out to 7000rpm quiet frequently.
it pinged a bit over 5.5/6rpm
while its out it would be better to give it a bit of a freshen up, prolly wont last too much longer.
so if u want one to put straight in and leave, you'd be better looking else where. sorry dude, but dont wanna sell you something that wont suit ya.
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Sun, 31 August 2003 11:43 Go to previous messageGo to next message
BUMP Very Happy
$200 for the motor, IT STILL GOES!!! Razz not completly buggered
come on, this all must go
air con units, one from ae92 and one from ae82
ae82 disc's with struts/springs
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Sun, 31 August 2003 23:04 Go to previous messageGo to next message
Come one, it must go!
$200 bucks and what ever else you want, just want the stuff gone!
swankiedude
Central Coast
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Sun, 31 August 2003 23:47 Go to previous messageGo to next message
I could be inserested in the motor and air-con unit. I have a AE92 cs seca so it has the standard carby motor so upgrading this is a must do and a rebuild with another engine is perfect. I have no aircon at all at the moment so how hard would an air-con unit be to install???
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 01:13 Go to previous messageGo to next message
umm, air con wouldnt be that hard to install i wouldnt think, iv only taken them out, not put one in, sorry Very Happy
swankiedude
Central Coast
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 01:21 Go to previous messageGo to next message
Does the air-con include everything like wires, in-cabin switches, everything else for a complete system???
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 01:27 Go to previous messageGo to next message
umm, yeh i spose so, i mean everything you need would still be on the half cut like the control side of things and wiring i spose.
swankiedude
Central Coast
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 01:46 Go to previous messageGo to next message
How much would you let the air-con unit go for???
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 01:53 Go to previous messageGo to next message
dunno, make a price and its yours, where you located?
fabke
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 07:16 Go to previous messageGo to next message
$200 engine, tranny, ecu and loom?
[Updated on: Mon, 01 September 2003 07:18]
Mr*Beach
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 08:54 Go to previous messageGo to next message
Air con is pretty easy to install. No wiring except the switch and amplifier which you just plug in anyway. Just pipes, evaporator, condensor and compressor.
Does the $200 include the gearbox, drive shafts, axles, brake set up, struts? Tax is comin back this week so I can afford to rebuild it. Also, do have a whole a/c system (compressor, condensor, evaporator, amplifier, switch and piping)? If so, how much u want for it? Cheers
swankiedude
If you have any questions about air con pm me and ill help u out. Ive done alot of a/c installing at my work.
~Josh
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 13:33 Go to previous messageGo to next message
i reckon 250 will cover all that you mentioned, or 300 with all the air con bits, theres a complete ae92 air con system, and a semi ae82 one, everything except the controls which are still in my car.
also the disk's might ned to be machined as they were sqealing when they were on.
also the clutch is pretty well buggered Very Happy sorry
for the engine/un-cut loom, ecu,FWD gbox and drive shafts 200$
i just want all this gone with in the next week!
any details call me on 0421813557
i'm located in Country vic also
swankiedude
Central Coast
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 22:17 Go to previous messageGo to next message
What would it cost to get the air-con unit sent to Gosford postcode 2250???
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Mon, 01 September 2003 23:40 Go to previous messageGo to next message
i dunno dude, id say 80-100 (incl the air con bits and peices) would cover everything, can find out for you if your keen
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Tue, 02 September 2003 13:46 Go to previous messageGo to next message
Sorry ppl, air-con sys has been sold
Mr*Beach
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Wed, 03 September 2003 07:54 Go to previous messageGo to next message
If you can find out exactly what the shipping costs would be it would be much appreciated. Is the compressor for the a/c off this motor or a different one completely? Cheers
~Josh
[Updated on: Wed, 03 September 2003 07:58]
Charlie
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Wed, 03 September 2003 07:59 Go to previous messageGo to next message
Price for just the box?
Mr*Beach
nevermind about the a/c question
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Wed, 03 September 2003 10:44 Go to previous messageGo to next message
Air con is sold anyways, sorry champ
the box, umm $70 +frieght?!
also got extra 86kw fuel rail $50
ae82 front struts/discs,brakes/springs and shocks, $100 the pair
86kw fwd inlet manifold $50
and a ke20 3k and 4sp box, $120
inertia
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Wed, 03 September 2003 11:26 Go to previous messageGo to next message
Who's doing the wiring dude?
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Wed, 03 September 2003 11:59 Go to previous messageGo to next message
wiring?! wiring to what champ?
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Thu, 04 September 2003 08:17 Go to previous messageGo to next message
also got ae92 dash $30
ae92 s/c instrument cluster $60
heater ducting $10
ae92 trueno steering wheel $20
[S.T.A.R.S]
ADELAIDE - Lenswood
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Thu, 04 September 2003 09:42 Go to previous messageGo to next message
isnt the instrument cluster and dash the same thing? e.g the thing with tacho,speedo etc on it
inertia
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Thu, 04 September 2003 13:17 Go to previous messageGo to next message
If ya got any pics of the wheel send them to: lo_inertia@hotmail.com
I'd be interested, I am in Melbourne.
Wiring: I meant who wired up the GZE? Cheers.
twincam_ke20
Castlemaine Vic
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Thu, 04 September 2003 23:24 Go to previous messageGo to next message
sorry dude, my bad, the instrument cluster thingy, with the speedo and stuff on it, and then the dash, that goes from one side of the car to other...that the glove box and all is attached too.
I'll take a pic later on in the day of the wheel for ya.
Umm im getting a guy from melb to do my wiring, he's just done the wiring on his ae82 seca gze so yeh, thought while its still fresh in his memory, to get him to do mine too Very Happy
--->PS MOTOR AND GBOX IS SOLD<---
inertia
Re: 86kw 4age motor/ecu and left over ae92 half cut bitsNpeices Fri, 05 September 2003 05:16 Go to previous message
Mate,
Think he'd be interested in helping me wire an AE92 Carby to a AE92 GZE heheh.
I will be offering BBQ/Alcohol to all who come and help me knock my conversion over later this year Smile
Thanks for taking the time to take pics.
Previous Topic:15X7 wheels for sale - Suit AE86
Next Topic:autotechnica steering wheel
Current Time: Sun Oct 25 03:40:08 UTC 2026
Total time taken to generate the page: 0.0072789192199707 seconds
