Toymods » Tech & Conversions » Battery Question - Amperage
manipulate
Battery Question - Amperage Sun, 31 August 2003 06:11 Go to next message
Hey all
quick question
lets say i replaced my 12 volt battery with a truck battery
still 12 Volts but with a shiteload more amperage
i know if u have more voltage it can blow things but is amperage ok ?
Ta
Mani
Re: Battery Question - Amperage Sun, 31 August 2003 06:22 Go to previous messageGo to next message
your car will only draw as much amperage as it needs. and it never hurts to have a battery capable of higher amps.
a bigger capacity battery can either be the total capacity, so you can run offf it longer, or higher discharge rate maybe, so you can power more off it without decreasing voltage.
bigger capacity battery is always good Smile (as long as it fits)
manipulate
Re: Battery Question - Amperage Sun, 31 August 2003 06:23 Go to previous messageGo to next message
much appreciated
Re: Battery Question - Amperage Sun, 31 August 2003 06:32 Go to previous messageGo to next message
A "Truck" battery is over rated and over kill! What do you need more amps for?
manipulate
Re: Battery Question - Amperage Sun, 31 August 2003 07:04 Go to previous messageGo to next message
i dont
but my celica's battery is dead from sitting there
and we got a truck battery at work thats sitting there doing nothing so i might as well charge it up and use it when i get around to selling it
hey im on apprentice wages i gotta be tight
Ta
Mani
Re: Battery Question - Amperage Sun, 31 August 2003 07:25 Go to previous messageGo to next message
Well thats ok then! I just dont reccommend going out and buying a truck battery when there are better batteries available.
manipulate
Re: Battery Question - Amperage Sun, 31 August 2003 08:04 Go to previous messageGo to next message
oh for sure
itd be damn pointless and itd weight more too
clubagreenie
1st street on the right
Re: Battery Question - Amperage Sun, 31 August 2003 10:51 Go to previous messageGo to next message
What you have to consider is cold cranking amps, how much it will push vs amp hrs, how long it will push for. Sealed batteries tend to have shorter amp hours but higher CCA. OK for start applications but long discharge like stereos not so good. You could try a batt to suit a BMW or Merc as they have a high CCA (550) and long amp hours, AND they are sealed caps AND vented as they are fitted inside cabins in these cars (in boot or under rear seats). Mine was approved w/out question by the RTA in boot and inside a std box with the vent tubes put through the floor. I think the century no is a DIN53 by memory.
This was information provided by local battery world. Also truck batteries apparently don't have a high amp hour rate as they azre usually used in 24v and with the pair of batteries is compensated for (again their info)
[Updated on: Sun, 31 August 2003 10:55]
manipulate
Re: Battery Question - Amperage Sun, 31 August 2003 11:05 Go to previous message
Thats very good info to know greenie thank u
Previous Topic:Gt4 side indicator removal - how ?
Next Topic:rx7 parts to fit ra60?
Current Time: Sat Oct 24 04:54:31 UTC 2026
Total time taken to generate the page: 0.0071680545806885 seconds
