Toymods » Tech & Conversions » Draining/Changing Transmission fluid in a Corolla Seca 4AC??
MADMR2
Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 06:53 Go to next message
As the topic says, I'm working on my G/F's car... how do i drain all the tranny fluid from a 4AC?? I removed the huge bolt located near the sump on the transmission side of the car, but all the fluid isn't pouring out. I've never done this before so I'm a bit lost Sad
Kman
Re: Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 07:12 Go to previous messageGo to next message
Sounds like you undid the filler hole.
The drain hole should be at the bottom of the transmission.
MADMR2
Re: Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 07:22 Go to previous messageGo to next message
Is there a website you or anyone can direct me to with pictures and instructions on how to do this?
I cant find the bolt to drain all the fluid out.
Kman
Re: Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 07:34 Go to previous messageGo to next message
Is it rear wheel drive?
MADMR2
Re: Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 07:37 Go to previous messageGo to next message
nup front wheel drive Smiley =
Kman
Re: Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 07:39 Go to previous messageGo to next message
Still, logically the drain plug should be at the lowest point in the casing.
MADMR2
Re: Draining/Changing Transmission fluid in a Corolla Seca 4AC?? Sun, 31 August 2003 08:04 Go to previous message
ok I think I've found it.
Thanks for your help!
Previous Topic:5r-18r hilux conversion
Next Topic:opinions on Jaycar Response speakers?
Current Time: Fri Oct 23 07:48:44 UTC 2026
Total time taken to generate the page: 0.0067191123962402 seconds
