Toymods » Tech & Conversions » head unit mount
darky
head unit mount Sun, 31 August 2003 08:04 Go to next message
Anyone out there got some advice for mounting my new panasonic mp3 head unit? Spent all weekend installing speakers, and wiring the mofo, I just wanna get it all finished! Is it possible to buy aftermarket h/u mounting kits for 4th gen celicas, but more specifically an 86 SX?
darky
Re: head unit mount Sun, 31 August 2003 10:51 Go to previous messageGo to next message
atm there is just a big gaping hole, with nothing that will support the deck. obviously i dont want to put it in there and have it banging around. surely there must be something i can buy, like a shelf that I can put in there? any help be greatly appreciated.
[Updated on: Sun, 31 August 2003 10:53]
Kman
Re: head unit mount Sun, 31 August 2003 13:32 Go to previous messageGo to next message
I take it you don't have the metal brackets on either side to support it?
I'm not firmilar with the 86 celcia, but both my sprinter and RA65 had support brackets that the head unit was attached to.
You have to remove the bracket attach the head unit and then screw the brackets back in.
darky
Re: head unit mount Sun, 31 August 2003 13:39 Go to previous messageGo to next message
The brackets do not screw into the head unit in any way. Confused
Skinnypoo
Tasmania
Re: head unit mount Mon, 01 September 2003 05:02 Go to previous messageGo to next message
Thats a bit of a shitta not being able to bolt the head unit straight into the brackets....I put a JVC Mp3 player in my 86 celica about a month ago and it bolted in fine, I just used the standard brackets of the radio and tape player....I was under the impression that they all had a universal bolt on system...to fill the big hole I just left the tape player in but its not connected but still looks better than having a blank space.
darky
Re: head unit mount Mon, 01 September 2003 06:51 Go to previous messageGo to next message
Would anyone know if its ok to drill into one side of the unit (the heatsink side) ? It already has dimples there, where the screw holes line up with the other side. But Im worried if any metal flakes get in there it might cause a short.
[Updated on: Tue, 02 September 2003 10:11]
darky
Re: head unit mount Tue, 02 September 2003 10:12 Go to previous messageGo to next message
*bump*
RobST162
Re: head unit mount Tue, 02 September 2003 10:15 Go to previous messageGo to next message
uh Jaxe on these forums just did a nightmare job installing his head unit.. Mine all had the correct mounts an everything.. piece of piss
here is a link to him
http://forums.toymods.org.au/index.php?t=usrinfo&a mp;id=3218&rid=2485&S=bb65b5c38f2cda7df077 cc31719db40f
munki
Gold Coast
Re: head unit mount Tue, 02 September 2003 10:17 Go to previous messageGo to next message
what headunit do you have. on my old celica they just screwed up to the headunit. what type of headunit do you have?
why not drill holes in the metal mounting brackets.
darky
Re: head unit mount Tue, 02 September 2003 10:46 Go to previous messageGo to next message
Panasonic CQ-RDP472N
I cant drill holes in the bracket because there are no holes in the actual unit on one side.
munki
Gold Coast
Re: head unit mount Wed, 03 September 2003 09:20 Go to previous message
so you have the two mounting brackets and a single din pocket? did your headunit come with the metal retcangle thingo? u know the bit that the unit slides into. you could rivit the metal thingo into the metal mounting brackets and slide the unit in. short of pics i cant see why you are having any sort of problem. all main brands use pre drilled holes for each car manifacturer so i cant see the problem.
hope it helps
Daniel
Previous Topic:1ggte
Next Topic:Strut Brace -> MA61?
Current Time: Fri Oct 16 15:33:19 UTC 2026
Total time taken to generate the page: 0.023041963577271 seconds
