Toymods » Tech & Conversions » 4agte clutch arm for w50
sebta22
4agte clutch arm for w50 Sun, 31 August 2003 10:08 Go to next message
I have finshed making an adpater plate to fit a w50 gearbox to the back end of a 4agte.
I can use the original clutch arm and thrust bearing but the contact point is right on the edge of the clutch fingers. Has anyone used done this conversion and which setup did they use: original w50 clutch arm and thrust bearing, 4agze clutch arm and thrust bearing or combination.
any help is great cheers
sebta22
Re: 4agte clutch arm for w50 Mon, 01 September 2003 03:01 Go to previous messageGo to next message
bump bump
sebta22
Re: 4agte clutch arm for w50 Fri, 05 September 2003 04:06 Go to previous messageGo to next message
bump .... any help?! Sad
CLG
Perth, Western Australia
Re: 4agte clutch arm for w50 Fri, 05 September 2003 05:02 Go to previous messageGo to next message
Are you using the W50 cast clutch fork and throwout bearing? What happens to the contact pacth if you use the T50 style throwout bearing on the W50 fork?
sebta22
Re: 4agte clutch arm for w50 Fri, 05 September 2003 05:10 Go to previous messageGo to next message
havent tried that as i dont have t50 bearing handy, is it larger than w50 bearing?
CLG
Re: 4agte clutch arm for w50 Fri, 05 September 2003 05:37 Go to previous messageGo to next message
I'd suggest comparing the two forks and throwout bearings, then change to suit your application. I have spare T50 forks and bearings if you are chasing a set?
sebta22
Re: 4agte clutch arm for w50 Fri, 05 September 2003 05:56 Go to previous messageGo to next message
are you able to measure the inner diameter of bearing and take a photo?? i think the w50 has bigger spline than the t50.
where you live in perth??
CLG
Re: 4agte clutch arm for w50 Fri, 05 September 2003 06:00 Go to previous messageGo to next message
Nope, I'm in Melbourne at the moment! The forks are at my parents place in Kalamunda if you want one though?
sebta22
Re: 4agte clutch arm for w50 Fri, 05 September 2003 06:22 Go to previous message
cheers for that! my car is at parents in lesmurdie as well. when you back in perth??
Previous Topic:RA28 Automatic Q & A.
Next Topic:RA28 P/S
Current Time: Fri Nov 20 12:37:13 UTC 2026
Total time taken to generate the page: 0.0085837841033936 seconds
