Toymods » Tech & Conversions » Cam Timimg on 18 rgeu
Shaun
Nelson NZ
Cam Timimg on 18 rgeu Sun, 31 August 2003 12:22 Go to next message
any one no how to do this i have got cylinder 1 at tdc its about 10 btdc on the pulley the cam gears have a mark on each they r at the top. what do i do form here?????
earlyrolla
Re: Cam Timimg on 18 rgeu Sun, 31 August 2003 13:43 Go to previous messageGo to next message
Assuming:
1) You have already removed the top adjuster in the side of the head
2) If you have the cam gears with adjustable holes, you have loosened both cam gear fixing bolts and the locating dowels
When No 1 is at top dead centre, one of the marks on the harmonic balancer should line up with the indicator (well at least this is correct for the earlier RG).
There are two slots cut out of the thrust flange of each cam (on the cam NOT on the gear). These two slots should be vertical and hence parallel to each other when No 1 is at TDC. There is an original Toyota tool available for this but it can be done pretty accurately by eye.
With the cams in the correct position, refit the cam gears and timing chain. If you have the adjustable gears, remove the locating dowel and rotate the cam gear with the chain on (by 'walking' the chain over the gear - dont turn the cams or the motor) till one of the dowel holes in the gear aligns with the one in the cams, this can take a couple of trys.
Once the cam gears are set properly and you have fitted the dowel and the chain is on, refit and set the upper chain tensioner. Now re-tension the cam gear retaining bolts.
Note: Always keep the 'pulling' side of the chain in tension when setting the gears (that is the passenger side of the vehicle or right hand side of the motor as you face it).
Be VERY careful when rotating the cams independently of the motor. You are better off to remove the cams and place them in the correct position then replace and re-tension the cam caps.
Hope this is clear enough Smile
Tyron.
Steve M
Re: Cam Timimg on 18 rgeu Mon, 01 September 2003 01:28 Go to previous messageGo to next message
When tightening the cam gear reteiner bolts (for adjustable timing cams esp.) make sure that you tighten it against a wrench on the hex part of the cam (near the front)to hold the cam in its place.
cam timing marks at 12:00 as the other guy said.
early rolla said everything else.
Steve M
Re: Cam Timimg on 18 rgeu Mon, 01 September 2003 01:30 Go to previous message
The timing marks on our 18rgu pulley are as follows. The first one (as engine turns around) to reach the timing pin on the timing case indicates 9.8 degrees BTDC. The second indicates TDC.
Previous Topic:Upgrades?
Next Topic:twinky speedo cable with gze?!
Current Time: Tue Oct 20 11:49:56 UTC 2026
Total time taken to generate the page: 0.072454929351807 seconds
