Toymods » Tech & Conversions » gze loom trouble in ae82
twincam_ke20
Castlemaine Vic
gze loom trouble in ae82 Sun, 31 August 2003 13:42 Go to next message
hey all
just having a bit of trouble getting the gze loom through the ae82 twinky's firewall, got the first few but cant get the yellow ones through, also, if i get it through it doesnt look like theres gonna be much length to plug the computer in, cos it will be right behind the heater box/fan.
any ideas?!
MaNGeW
Formerly TRD_RoLLa
Re: gze loom trouble in ae82 Mon, 01 September 2003 00:14 Go to previous messageGo to next message
Hey,
You either have to extend the loom to fit into the OEM AE82 Loom gromet.
Or....
Create another hole into the firewall like the AE92 ECU gromet position which is more central than the AE82 position.
twincam_ke20
Castlemaine Vic
Re: gze loom trouble in ae82 Mon, 01 September 2003 01:13 Go to previous messageGo to next message
i dont really wanna re-drill another hole for it, but then again , extending all those wires sounds like a big job as well.
what do you think would be the easyest and best way? cos if i have to drill a new hole i'll have to move a heap of shit to get in there, or if i extend all the wires. thats alot of soldering lol and heat skrink
MaNGeW
Formerly TRD_RoLLa
Re: gze loom trouble in ae82 Mon, 01 September 2003 12:16 Go to previous messageGo to next message
Ok your options are as follows....
1. You extend the wires on your GZE loom which go into the cabin. (Trying to keep all the colours the same albeit optional on your personal preference) This may take a day to a week.
2. You use the existing AE82 loom hole but you will find that you will not be able to put the new ECU in the factory location. So you can relocate the ECU closer toward the passenger side. (eg. under the carpet)
3. You keep the factory ECU position and use a door handle hole type drill creator thingy (sorry dont know what its called)
and just create a new hole like the half-cut one. But make sure you position it well otherwise it will not clear the heater box and pipes on the interior side of firewall.
Then just plug up your old hole.
Hope it helps. Smile
I chose option 3. As it was the quickest and easiest whilst still retaining factory ECU position.
twincam_ke20
Castlemaine Vic
Re: gze loom trouble in ae82 Mon, 01 September 2003 13:35 Go to previous messageGo to next message
you mean a hole cutter thing? circle saw?
yeh i went and bought one today actually Very Happy havent tried to drill a new hole yet, havent had time. but hope it cuts through alright
sideshow
Re: gze loom trouble in ae82 Mon, 01 September 2003 13:37 Go to previous messageGo to next message
i have done em b4
u can just get the plugs on the ecu
u have to undo the small bolt holding part of the loom on the side of the manifold
then u pull abit on the loom
the only prob is the ecu hangfs in bad spot
best way is to drill a hole in middle of firewall just elow heater and beware of clutch hydraulic metal line
twincam_ke20
Castlemaine Vic
Re: gze loom trouble in ae82 Mon, 01 September 2003 23:43 Go to previous message
yeh im gonna drill a hole today, i have cleared all the pipes and shit so thats alright, the hole is around where theres little tab that holds the plastic on in the engine bay, should be alright i hope.
was the fire wall easy to cut?
ps.sideshow, didnt u get my e-mail yesterday inquiring the wiring?
Previous Topic:Looking for engine conversion into my gz10 soarer
Next Topic:encoders VS crank angle sensors
Current Time: Sat Nov 21 05:18:58 UTC 2026
Total time taken to generate the page: 0.0040969848632812 seconds
