Toymods » General Car Talk » DIY Shortend Shifter
DJBlade091
Central Coast NSW
icon3.gif  DIY Shortend Shifter Thu, 11 July 2002 23:54 Go to next message
Heyo,
Has anyone shortend a shifter in an AE92 themselves...? How low did you go? Any probz since doing it ?
Can you actually buy a shortend shifter for a AE92?
I've seen them for AE101's but not eariler... Sad
I want to do it, but I cant find any mates with a Tap & Die Set...
So if there's anyone around the Central Coast / Newie Ares That has one and wants to give a fella rolla driver a hand please lemme know....
raSkaS
Perth WA
Re: DIY Shortend Shifter Fri, 12 July 2002 01:14 Go to previous messageGo to next message
Yep ive done that mod on my ae92 Levin, i only cut about 40mm off mine, and it took a while as the steel used for the shifter is very hard. Ive also unbolted the complete shifter mechanisim ans raised it 80mm to get the shifter where i wanted it
i know you can by short shifters for ae92s in the US but thats no good for a RHD vehicle as it bends away from the driving position .... maybe try TRD japan ?!
DJBlade091
Central Coast NSW
Re: DIY Shortend Shifter Fri, 12 July 2002 01:53 Go to previous messageGo to next message
What did you use to cut it ?
i was thinking oxy torch Evil or Very Mad and then put a new thread on it, cool, around 40mm sounds pretty much how far i want it dropped btw i'm 6"1 so easier to reach instead of bending my arm
I Thnk TRD Shifters would be good but $$$$
raSkaS
Perth WA
Re: DIY Shortend Shifter Fri, 12 July 2002 02:16 Go to previous messageGo to next message
Yeah TRD is big Smiley $$ thats why i cut mine
i cut mine with a dremel tool , but id say if you had the time you could cut it with a hacksaw
i guess you could torch it but make sure you cut the thread first ,as its quite hard to restart a thread of that diameter and with that grade of steel, and if you can use a dremel you wont need to take the shifter outta the car.... which may not seem relevant, but remember how much force it takes to cut the thread and you cant get it to hold in a vice to well
if i could work out how to post a photo i could show you what ive done Confused
raskas
DJBlade091
Central Coast NSW
Re: DIY Shortend Shifter Fri, 12 July 2002 03:16 Go to previous messageGo to next message
you can email it to me at cdekort@ccgs.nsw.edu.au
GT4_Steve
Sutherland, Sydney
icon4.gif  Re: DIY Shortend Shifter +Shortshift URL link Fri, 12 July 2002 12:16 Go to previous messageGo to next message
G'day,
just thought I'd say how much a difference lengthening* your
shifter makes to your gear changes. Shortening is good, but you should combine that with a shorter throw while you row.
If you are just going to shorten the shifter only then here's a note on cutting that tough steel. Grab a good (or new)hacksaw blade plus a helpful, albeit game, friend with a strong grip to hold your shifter while you hack. Should only take a minute or so. Make sure you wrap an old sheet or towel around it to catch the filings.
If you don't give a rats about quality or are waiting for a tap/die kit, whack a Supercheap Auto gearknob on it which is fastened on with 3 allen key bolts.
*the shifter is lengthened below the pivot point.
Rather than explain something you may already be aware of, feel free to check this short shifter mod site for an ST185.
http://member.newsguy.com/~gtfour/shifter.htm
RA28
Re: DIY Shortend Shifter Sat, 13 July 2002 10:44 Go to previous message
My 77 celica had a real long shifter, it stuck op real high near the dash. When I went to cut it I realised I couldn't as the celica shifter gets thicker near the bottom so I couldn't cut any more off, so I just cut it in 2 places, taking out about 2"-3" and also taking out the fat bit, and welded it back together. much eaiser than a tap-and-die, I used a metal dropsaw to cut mine.
Tim
Previous Topic:My Suzuki shits on your Toyota!
Next Topic:neg driving... ?
Current Time: Sun Nov 22 10:01:56 UTC 2026
Total time taken to generate the page: 0.014339923858643 seconds
