Toymods » Tech & Conversions » replacing headlining in TA22
ra23celica1977
SYDNEY
replacing headlining in TA22 Mon, 01 September 2003 06:05 Go to next message
I was wondering if anyone has done this themselves and wanted to know if the windscreens need to come out to do it? any info would be great!
mr_ice55
Mooroolbark, Melbourne
Re: replacing headlining in TA22 Mon, 01 September 2003 06:52 Go to previous messageGo to next message
i have redone my roof lining in my 74 ta22, for the job to be done properly the windows do need to come out as the lining tucks under the window rubber, i guess it could be done with the windows in, but it would be easier if the windows were out. I had to do it all by myself and i found it a prick to get the lining straight without any creases. And another tip, dont do it while ur drunk, it doesnt help when trying to find where the holes are for the sun visors, and seat belts Very Happy
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: replacing headlining in TA22 Mon, 01 September 2003 08:30 Go to previous messageGo to next message
I also replaced mine, I had my mum sew up a nice velour one Smile, and yeah you gotta remove the windscreens.
Before you put the lining in, go out & spend about $5 on those black springy clips you get from stationery shops, you need about 50 of them, but the smallest cheapest ones are perfect.
Then just use the clips to hold the lining to where it folds under the windscreen seal, have one evry 10cm or so, then just go around & straighten it up one clip at a time. Once it's all perfect give it a trim, so it doesn't come too far past the windscreen seal, otherwise it will act like a wick & draw in any moisture that works its way past your chrome surround, then get some contact adhesive & go around & stick it all down, a small section at a time, replacing all the clips.
Once it's dried for a while (leave the clips on for as long as possible), the winscreen will be easy to install & your roof lining won't wrinkle as it's being installed.
ra23celicachick
Mornington Peninsula
Re: replacing headlining in TA22 Mon, 01 September 2003 22:21 Go to previous message
I need to put a new one in my car. My windscreen is out so I'll do it after I get the re-spray.
When you say black springy clips do you mean bulldog clips????
I was looking at getting a nice velour one, I can sew myself up one in no time. Smile
Previous Topic:encoders VS crank angle sensors
Next Topic:Sprinter and Trueno front..
Current Time: Sat Nov 21 05:23:42 UTC 2026
Total time taken to generate the page: 0.010143041610718 seconds
