Toymods » Tech & Conversions » 4agze in sprinter
sideshow
4agze in sprinter Mon, 01 September 2003 22:45 Go to next message
hi guys
i wired up a 4agze in a sprinter recently
the customer says its idling funny sometimes
idles up and down sort off
coul;d this be due to him turning the intake around on the manifold, it used to face towards back of engine he now turned it around to face front of car and some vacuum ports are now blocked
or could it be due to it having an external thermostat on the
bottom rad hose therefore gettin the wrong temp reading
if anyone has done this conversion have u turned the intake around to face the front??
Henn
Rosanna, Melb
Re: 4agze in sprinter Tue, 02 September 2003 15:29 Go to previous messageGo to next message
I've seen this pipe reversed before. "Sprinter" on these forums did it in his car and apparently has been running it for several years. Best to ask him personally though.
I think it is generally common to flip this pipe when GZEing a Sprinter, so I doubt it would be causing the idle problem.
Hen
EVOSTi
cambo
      no
Re: 4agze in sprinter Wed, 03 September 2003 08:25 Go to previous messageGo to next message
my intake pipe is spun around, but im currently not running a thermostat. my idle goes up and down but i thought it was due to having a solid s/c pulley.
J.E.M
Re: 4agze in sprinter Wed, 03 September 2003 14:55 Go to previous message
Hi Sideshow,
what ecu is it running? if aftermarket then it could be tuning..
could be running too adavanced timing for idle, 14-17 usually keeps a gze happy, also couild be too lean, this will cause hunting...
make sure the blower is disabled at idle,
Previous Topic:?? 4AGE Flywheel Weight ??
Next Topic:Idea for Sprinter
Current Time: Mon Oct 19 23:51:44 UTC 2026
Total time taken to generate the page: 0.0039000511169434 seconds
