Toymods » Tech & Conversions » -------> Faulty TA22 Temp Gauge
boris
On probation
Brisbane, Queensland
-------> Faulty TA22 Temp Gauge Tue, 02 September 2003 03:50 Go to next message
hey all,
recently i noticed that the temp gauge in my ta22 isn't working anymore. Can anyone tell me where abouts the sender for it is located and what things i should check? It is just the stock 2T engine.
Cheers.
Re: -------> Faulty TA22 Temp Gauge Tue, 02 September 2003 08:08 Go to previous messageGo to next message
Its on the water outlet! Where the thermostat is.
juzzo84
Hornsby, N.S.W
Re: -------> Faulty TA22 Temp Gauge Tue, 02 September 2003 08:52 Go to previous messageGo to next message
you will often find that the connections on the back of the gauge may just require a good clean up. Smile
justin
Re: -------> Faulty TA22 Temp Gauge Tue, 02 September 2003 08:59 Go to previous messageGo to next message
You will also often find that the wire just falls off the sensor.
boris
On probation
Re: -------> Faulty TA22 Temp Gauge Tue, 02 September 2003 22:09 Go to previous messageGo to next message
Turns out it was the old wire falls of the sensor gag. Embarassed
Re: -------> Faulty TA22 Temp Gauge Wed, 03 September 2003 08:49 Go to previous messageGo to next message
Laughing I hate to say it, but I told you so Razz
gmsta27
Fl
Re: -------> Faulty TA22 Temp Gauge Thu, 04 September 2003 02:20 Go to previous message
For future reference you can check the gauge by taking the wire off the sending unit and grounding it on the block with the key on. If the gauge is good it will peg out.(go to hot) all the gauges will check this way.( Fuel, oil pressure, temp) You can do this to see if the gauge or the sending unit is bad.
Greg
Previous Topic:dash loom?
Next Topic:Urethane engine mounts - where in Melbourne?
Current Time: Fri Oct 23 18:43:16 UTC 2026
Total time taken to generate the page: 0.0047690868377686 seconds
