Toymods » Tech & Conversions » 3s-fe swap questions
fordp
Ottawa Ontario Canada
3s-fe swap questions Tue, 02 September 2003 18:39 Go to next message
Hi All;
I don't know how you guys will welcome me, I'm swapping a 3s-fe into a suzuki sidekick, so it isn't really a toy I'm modding.
When you guys swap either the 3s-fe or the ge engines is there a distributor the fits without going through the firewall? Or a right angle adaptor like the suzuki's use?
Is there any online wiring diagrams for the fe engines efi? I've found lots for the ge or the 5s-fe but it doesn't help.
The donor car was an 87 celica, and the engine is going into a 92 sidekick, it should be a good match, size and weight seems good and I'll get close to 2X the power and torque.
If you are wondering why I didn't just get a landcruiser or Rav4 both are expensive here, and the Rav4 doesn't seem to last with heavy offroading. The Cruiser would be nice but most of the trails I do are narrow.
Pat
wizzfizz2097
Re: 3s-fe swap questions Tue, 02 September 2003 23:31 Go to previous messageGo to next message
find your self a mechanics guide for the donor car, or a sv21 camry... same engine, i have one Smile
Re: 3s-fe swap questions Wed, 03 September 2003 00:09 Go to previous messageGo to next message
What some have done is to attach the dizzy to the front of the cam gear, which is a bit messy and needs to be done carefully, but if you want to keep the stock ECU looks like it might be your only choice. I guess the *really* rough thing to do is what they used to do with supercharged V8s, and run a thin toothed belt straight off the crank pulley, 2:1 ratio... that that would be just plain messy and unreliable... Twisted Evil
fordp
Re: 3s-fe swap questions Wed, 03 September 2003 11:37 Go to previous message
mrshin wrote on Tue, 02 September 2003 20:09
I was hoping something else might slide in, one of the more boring swap done on sidekick is a swift GTI engine, but it has the same dizzy problem. It turns out that a Mazda dizzy bolts in and just needs a new connector to work and only sticks out ~40mm from the back of the head. I hadn't thought of the belt drive, I don't think it would last long, I use the truck offroad a fair bit ( that why I want the Toy reliability, offroad drive is fun, hiking back isn't Confused )
Any ideas about the intake pointing the wrong way? I was thinking maybe put the airfilter inside the truck.
Pat
Previous Topic:4ac cooling
Next Topic:1JZ-GTE standard fuel pressure
Current Time: Sun Oct 18 10:52:00 UTC 2026
Total time taken to generate the page: 0.03380298614502 seconds
