Toymods » Tech & Conversions » strut conversion
amon
Darwin
icon5.gif  strut conversion Wed, 03 September 2003 07:19 Go to next message
Confused Can i use corona ST141 struts in my RA28, brakes en all and what other bits may transfer<diff,etc>or bolt straight up.As the bits are better than my bits.Ta Confused Amon
[Updated on: Wed, 03 September 2003 10:37]
Andy_H
Westleigh, Sydney
Re: strut conversion Fri, 26 December 2003 06:56 Go to previous messageGo to next message
yeh i need to know the same, there is a ST141 for sale down the road for $200. i need to know whether i can use the struts off that, or does it have to be off a xT130???
if i bought the car would anyone else want any parts???
rxtoy
Auckland NZ
Re: strut conversion Fri, 26 December 2003 07:22 Go to previous messageGo to next message
i enquired about this a week or two ago, apparently the st141 one's won't bolt up because the spacing between the bolts at the bottom is 100mm instead of 90mm. you could change the steering arms as well but finding ones the right length would probably be a bit of a mission, easier to just find some xt130 struts.
CLG
Perth, Western Australia
Re: strut conversion Fri, 26 December 2003 07:24 Go to previous message
The struts will not bolt in as such - they run a different and larger sized ball joint, but it can be done if you're prepared to work at it. The easier option of the two is still to go for the XT130 style struts. Diff will also be larger in track and I doubt bolt in, especially if it's IRS. Basically, as the later model stuff is designed on a different platform to the earlier model Celicas, nothing will bolt in easily, but will all need some form of modification.
Previous Topic:anyone know where to get shock dimensions
Next Topic:Weatherstrip Alternative
Current Time: Thu Oct 29 12:59:27 UTC 2026
Total time taken to generate the page: 0.0082859992980957 seconds
