Toymods » Tech & Conversions » Electric Fan or Engine drive fan ??
86racer
Electric Fan or Engine drive fan ?? Fri, 12 July 2002 14:18 Go to next message
I'm putting an 100KW 4age into AE86 sprinter...I would like to know whether it's better to run electric radiator fan than engine driven radiator fan.. I've heard that with electric fan the engine revs bit better and gives about extra 5hp than engine driven fan...what are your guys opinion ???
jazae86
Re: Electric Fan or Engine drive fan ?? Fri, 12 July 2002 14:39 Go to previous messageGo to next message
You need to be running the RWD water pump front housing to space the fan close enough.
The power gain you pick up you loose in driving the alternator. Try a Camry fan, i think that's wht I've got. On the AE86 it fits nice, one bolt hole lines up and the other just needs an extension piece.
Jaz
Edit: It should just be RWD only.
[Updated on: Sat, 13 July 2002 06:38]
IRA11Y
Club Member
Re: Electric Fan or Engine drive fan ?? Fri, 12 July 2002 22:39 Go to previous messageGo to next message
jazae86 wrote on Sat, 13 July 2002 12:39 AM
Jaz
Uhmmm maybe you should rethink this a bit..........how often do you think the thermo fan will switch on and when is it likely to do so?
I suggest that if youre cooling system is running properly then the only time you would need your thermo is when the car is standing still in traffic. And i dont think thats going to affect your performance too much seeing as you will be pretty close to travelling at 0kms Smile. the only other time is if you were really giving the engine a long consistenet thrashing under extreme load, i.e at a track where it is likely you will be moving fast enough for the engine to cool with airflow anyway, I doubt you would be able to give it the same punnishment for long enough to switch the fan on while driving on public road, more likely is you give it some and come close to standstill and the fan will switch on then.
by using the thermo fan you reduce a large amount of uneccesary parasitic drag and can in fact get about 2-4Hp increases. the thermofan alos weighs less so you also reduce your overall weight. If youre that worried about power loss then just use the 100Kw alternator which is a bit stornger.
In my experience a thermo fan is the better option but each to thier own I guess Smile
toyrota
Re: Electric Fan or Engine drive fan ?? Sat, 13 July 2002 05:53 Go to previous messageGo to next message
my thremo fan is wired up to a proper switch and is set up to work only when needed.Lately it has hardly had to come on as the days have been cold enough for it not to reach to temp that the switch is set at.Thremos are the way to go but wire them up properly and you will have no probs
Bill Sherwood
Brisbane / Gold Coast
Re: Electric Fan or Engine drive fan ?? Sat, 13 July 2002 06:24 Go to previous messageGo to next message
There's only one choice - Electric fan.
You can run an engine driven fan, but what you have to do is use a RWD water pump, as they have a longer shaft sticking out the front, and that locates in the back of the viscous fan hub. The FWD water pump doesn't have that, so at 5400rpm the fan assembly will develop really nasty harmonic imbalance that will literally rip the front of the water pump clean off.
You'd also need a RWD offset pulley.
How do I know this?
Because I have done it - twice! I thought I'd stuffed up fitting the fan the first time, so I did it very carefully the second time but at exactly the same rpm the whole fan and front half of the water pump broke right off. The radiator had a large gouge ripped in it, and the water pump backing plate thing was also broken in half.
So since you already have a FWD type water it's probably a better idea to get an electric fan anyway. Wink
jazae86
Re: Electric Fan or Engine drive fan ?? Sat, 13 July 2002 06:34 Go to previous messageGo to next message
I stand corrected.
I was thinking more along the lines of constantly on elec fan.
In any case, I agree. I would put an elec fan on to replace a belt driven fan due to ease of use and the fact that, as you suggested michael, you only need to operate them at certain times, thus being more beneficial.
Jaz
TCHOON
Sydney- Sutho Shire &...
Re: Electric Fan or Engine drive fan ?? Sat, 13 July 2002 10:04 Go to previous messageGo to next message
I fitted a davies craig fan to my other (non toyota Shocked ). If any car needs all the hp it can get, this is it!
I also fitted a potentiometer so I can adjust the cut in temp.
For serious cooling effect, have a look at a late model Falcon. They have a twin set up that isn't too deep. I saw one today but didn't measure it up Sad
86racer
Re: Electric Fan or Engine drive fan ?? Sat, 13 July 2002 23:44 Go to previous message
Thanks for all your guys information..
I guess I'll go for thermo fan . Very Happy
Previous Topic:dizzy diaphram 2tgeu
Next Topic:Electrical problems
Current Time: Mon Oct 19 17:04:21 UTC 2026
Total time taken to generate the page: 0.018014192581177 seconds
