Toymods » Tech & Conversions » bosch single wire 02 sensor-4agze.
feral4mr2
Bundaberg, Qld.
icon7.gif  bosch single wire 02 sensor-4agze. Wed, 03 September 2003 23:23 Go to next message
Freak does anyone know the bosch part number to replace a single wire 4agze 02 sensor?
thank's.
Re: bosch single wire 02 sensor-4agze. Thu, 04 September 2003 08:59 Go to previous messageGo to next message
Heya,
does it have a flange or is it screw in??
why not go to a four wire one?
feral4mr2
Bundaberg, Qld.
Re: bosch single wire 02 sensor-4agze. Thu, 04 September 2003 09:54 Go to previous messageGo to next message
it has the flange, i found a Tridon replacement single wire at work today that will plug straight in.
the reason i dont go 4 wire is that my ECU doest control pre-heat, meaning i would have to build a pre-heat set-up to run it. i know the pre-heated (4 wire) ones are spose to be more accurate. maybe next time i will try one.
thanks.
Re: bosch single wire 02 sensor-4agze. Thu, 04 September 2003 23:20 Go to previous message
feral4mr2 wrote on Thu, 04 September 2003 19:54
afaik, the heated sensors have a heater that is self regulating, ie it draws a constant current of 1 or 2 amps, the wide banmd sensors have a diffusion cell circuit and require a driver circuit, but i'm pretty sure NB 4 wires are fine just to hook up and go..
anyone else know?
Previous Topic:coil n ignitor for 2tg
Next Topic:do RA60's have adjustable steer column?
Current Time: Fri Nov 20 16:01:05 UTC 2026
Total time taken to generate the page: 0.0042881965637207 seconds
