Toymods » Tech & Conversions » Brake Upgrade Question...
Doctakay
Branxton
Brake Upgrade Question... Thu, 04 September 2003 12:35 Go to next message
Hi all,
Done a little bit of scratching around and have come up with pretty much nix. Sad I'm wondering if anyone has done a brake upgrade for the sv21 camry before? I'm inclined to believe that celica st165 discs and calipers would do the trick and sw20 mr2 atmo's might too but it's hard coming up with dimensions. They're to go under 15" rims. I've seen a bloke with a 3s-gte sv21 camry on a pulsar forum it's got something like 300 mm discs, could this be rav4 items? Rolling Eyes
DBA only offer a vented slotted upgrade, and they're only for the standard caliper as far as they could tell me.
Much appreciated if you could throw some info this way or know of anything like this done before...
Cheers!
TheStitt
Membership Secretary
Re: Brake Upgrade Question... Thu, 04 September 2003 13:33 Go to previous messageGo to next message
Go and see Pitwater Brake and clutch ( club sponsor) They should look after and have what you want. Phil was able to help me out alot with the wagon
ra23celica
Re: Brake Upgrade Question... Thu, 04 September 2003 13:35 Go to previous messageGo to next message
Have not done this job but with the 165's brakes being very similar in size to the SV21 I can't see any advantage in going this way. If you are trying to squeeze under 15 inch rims maybe look at the st185 rotors, 278mm vented fronts, 288mm solid rears.
I don't know if those calipers would even bolt onto your Camry
struts. This is all I know and can suggest. Good luck.
Mitch.
[Updated on: Thu, 04 September 2003 13:36]
CamryMan
Re: Brake Upgrade Question... Mon, 29 September 2003 06:00 Go to previous message
Yes, my SV21 Camry has GT4 single piston brakes off a ST185. It's a straight bolt on mod but you have to have 15" wheels at a minimum. I had a tech article at one stage. Max never got around to putting it up.
http://www.geocities.com/ignatius_tse/brakes/index .htm
It's heaps better going downhill. I would have like to get it slotted as well at racebrakes but haven't had the time.
Previous Topic:Rubber kits -where to?
Next Topic:Weighbridge: where is one near Blacktown or Smithfield?
Current Time: Sat Oct 31 23:44:55 UTC 2026
Total time taken to generate the page: 0.0039730072021484 seconds
