Toymods » Tech & Conversions » Sprinter Diff
bloody_huge23
Sprinter Diff Fri, 12 July 2002 23:05 Go to next message
Hey,
How wide is the sprinter diff from the center of the wheel to the other center..
Would yous recommend it in a KE30 4AGE? GB is a Sprinter T50.
And would i need to get the diff or the tailshaft cut down??
Thanx,
Adam
bloody_huge23
Re: Sprinter Diff Sat, 20 July 2002 02:57 Go to previous messageGo to next message
anybody got an idea?
Thanx,
Adam
Re: Sprinter Diff Sat, 20 July 2002 06:11 Go to previous messageGo to next message
I can't remember off the top of my head - I'll measure it up for you tomorrow morning, as I've got one sitting in the backyard.
Jonny2TG
Tasmania
Re: Sprinter Diff Sat, 20 July 2002 07:11 Go to previous messageGo to next message
I am using a RA23 Celica diff in my KE35, and the width is almost the same as the KE35 one, 5-10mm different. The Sprinter one would not be too much wider. There is lots of room under the KE30 rear gaurds anyway, they need to be filled. I have the T50 in the standard location, and used a TA22 1 piece tailshaft cut down 50mm. This is for the 6.7" diff. If the sprinter diff you are using is a Australian one, it may be a 6.38" diff and the tailshaft bolt pattern and length may need to be slightly different, not sure. You will want to use a 1 piece tailshaft, not the sprinter one.
Re: Sprinter Diff Sun, 21 July 2002 03:52 Go to previous message
I measured it up this morning, 1420mm
Previous Topic:Using N/A cams on 7MGTE??
Next Topic:ARP head bolts: 7m into 5m ??
Current Time: Sun Oct 25 19:45:11 UTC 2026
Total time taken to generate the page: 0.0048608779907227 seconds
