Toymods » Tech & Conversions » JP pistons - does someone on here work there??
ed_ma61
Lost in the K hole
icon5.gif  JP pistons - does someone on here work there?? Fri, 05 September 2003 10:22 Go to next message
Am just curious as i remember i read something that gave me the impression someone on here either worked at JP pistons, or had something to do with their work... ive tried search, but cant find it...
anyway - im just wondering exactly what kind of work they are capable of doing. they cast classic and historic pieces, i know, but i was wondeering if they can also do castings to custom requirements/designs, or even 'blanks' ie: cast pistons to a given bore/gudgeon pin/crown height but with a solid 'blank' top into which someone can then CNC or mill their own crown design and flycuts?
if someone knows, or if someone knows anywhere else that does this, please feel free to voice up Smile
(and yes i realise the like of JE do this kind of thing Smile )
ed
CelicaRA45
nth ringwood, Victoria
Re: JP pistons - does someone on here work there?? Sat, 06 September 2003 07:33 Go to previous messageGo to next message
ed try pattersons in dandy they do forge pistons to any bodies requirements you give them the specs and they will do for you
they are called special piston services
TA22-3SGTE
MACKAY
Re: JP pistons - does someone on here work there?? Sat, 06 September 2003 10:17 Go to previous messageGo to next message
Also try( Precision engine parts) they make pistons and rings to order .
ed_ma61
Lost in the K hole
Re: JP pistons - does someone on here work there?? Sat, 06 September 2003 12:25 Go to previous messageGo to next message
thanks guys Smile
will be calling around...
as usual, prices are, oh, only doubling what i expected...
ed
Steve M
Re: JP pistons - does someone on here work there?? Sun, 07 September 2003 12:35 Go to previous message
If you don't need forgies then JP's could do the job for you.
If you ask for a blank top, they will make a blank top for you.
Their prices are fixed, so if you don't want machining, it will not be any cheaper.
$660 for the set, maybe cheaper without rings (you'll want different rings)
I have been posting info about these guys lately but I do not work for them, I just had them do some research for me for 18rgu pistons.
If you want more info I can probably help.
stevemoulds@bigpond.com
Previous Topic:Which is better Hills motor sport or UAS
Next Topic:Gen. 3 3SGE into 86 celica
Current Time: Fri Nov 20 21:53:18 UTC 2026
Total time taken to generate the page: 0.036139011383057 seconds
