Toymods » Tech & Conversions » I'm new & for my first post a very technical question
turbotrdcelica
United States
icon4.gif  I'm new & for my first post a very technical question Fri, 05 September 2003 15:27 Go to next message
Here in the states the most popular thing to do is swap a 3s-gte into a FWD celica. We dish out anywhere from $1,000 to $3500 depending on the model for a clip. We get into the swap & get it all done we remove the rear ouput shaft & cap it off we custom hybrid axles, & it drives, it goes, but it constantly feels like the clutch is slipping. I have come to the conclusion that the ST185 tranny has either some kind of spider gears that transfer torque from the front to the rear or is has a viscous coupling setup. The problem we have is that we dish out this ungodly ammount of cash on a clip & then it takes way longer than it was supposed to, way over budget we finally finish it to find out we have to spend another $1500 on a tranny MR2TURBO tranny!
Is there any way to lock the center differential so 100% of the power is transfered to the front instead of a 50/50
I thought of a Kaaz LSD unit but I am not sure if that would work either
here is a link to the topic on celica.net
http://celica.net/cgi-bin/ultimatebb.cgi?ubb=get_t opic;f=37;t=001464
Hopefully someone has some experience with this
THANKS IN ADVANCE
[Updated on: Fri, 05 September 2003 15:28]
BansheeBuzz
Gold Coast
Re: I'm new & for my first post a very technical question Fri, 05 September 2003 21:25 Go to previous messageGo to next message
why not use a tranny from a 3s-fe or 3s-ge?
You could modify that tranny if you pulled it apart but unless you can do it yourself it will cost you.
Draza
Wahroonga
Re: I'm new & for my first post a very technical question Fri, 05 September 2003 23:38 Go to previous messageGo to next message
if u just want it finished the i used the sv21 box, for my 3sgte fwd st162 conversion, maybe the tranny will have the starter in the same position as the box, i don't know.
To answer bansheebuzz's question, the starter motor for the celica box and tranny sits where the turbo piping is. And the MR2 turbo box is from a 3sgte, so it can handle the force. The sv21 can handle the force so long as u don't push it to hard.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: I'm new & for my first post a very technical question Mon, 08 September 2003 00:03 Go to previous message
This thread might be of interest.
http://forums.toymods.org.au/index.php?t=msg&t h=17938
Previous Topic:soarer TT brakes on to a sw20 T
Next Topic:20V conversion - Pls Help!!!
Current Time: Wed Oct 14 10:44:10 UTC 2026
Total time taken to generate the page: 0.023952960968018 seconds
