Toymods » Tech & Conversions » need info on lsd gear box ae92
tin can
need info on lsd gear box ae92 Sat, 06 September 2003 11:15 Go to next message
ok i thought i new if my gear box is lsd but now im not that sure could u guys give me a hand and tell me how to tell if i have a lsd gear box
p.s the box is not in the car and i dont have shfts onlt a half one
thanks all
jess
Corvid
Re: need info on lsd gear box ae92 Sat, 06 September 2003 11:28 Go to previous messageGo to next message
put a driveshaft in and turn.. then look through the other side.. it should spin in the direction your turning the shaft..
tin can
Re: need info on lsd gear box ae92 Sat, 06 September 2003 11:41 Go to previous messageGo to next message
ive done that its duz turn the same way but is there any other ways to check
sideshow
Re: need info on lsd gear box ae92 Sat, 06 September 2003 12:06 Go to previous messageGo to next message
hold one front wheel and turn the other fornt wheel
if its has slight drag on it its viscous
if it has a fair bit of drag it is probably lsd
not sure if this is right with toyota diffs
its just a general assumption
tin can
Re: need info on lsd gear box ae92 Sat, 06 September 2003 12:12 Go to previous messageGo to next message
thank you very much all this info is helping but still dont no yet box isnt in car and i cant find shafts and then if i do which one is a trial and errror thing
Re: need info on lsd gear box ae92 Sat, 06 September 2003 14:42 Go to previous message
plenty of info on this at www.twincam.org
unless this box is from a 4A-GZE motor/front cut, then it most certainly isn't LSD.
Previous Topic:Fuse box'es st162
Next Topic:RA60 Questions
Current Time: Fri Nov 20 17:54:02 UTC 2026
Total time taken to generate the page: 0.0045289993286133 seconds
