Toymods » Tech & Conversions » boost gauge
knackers
berala sydney
boost gauge Sun, 07 September 2003 10:39 Go to next message
hi can some one explain to me how to connect a boost gauge up
it is just boost not boost& vac
thanks knackers
[Updated on: Sun, 07 September 2003 10:40]
celicaboy_2000
Lismore, NSW
Re: boost gauge Sun, 07 September 2003 10:46 Go to previous messageGo to next message
Hey, Look for a vacuum line on the plenum after the throttle and put a T piece in between and connect you boost guage to that. Not all the vacuum lines will be suitable tho so in your case I'd T off the Line which goes from the Plenum to the fuel pressure regulator. Does that help at all?
Re: boost gauge Sun, 07 September 2003 11:08 Go to previous messageGo to next message
well that depends on what you want to measure Rolling Eyes
if you want to measure the boost in the plenum, hook it up to a fitting on the plenum. if you want to measure boost in the runners, do it there. same for throttle body, or pre-TB
it makes no difference if "it is just boost, not boost& vac" it will just not register the vacuum, even tho vacuum is applied to it....
why would there possibly be a difference in hooking it up??
and it is not a boost gauge, it's a pressure gauge that is labelled "boost" Very Happy you have to hook it to somewhere that has pressure to measure. (and if it's carbed, not ported vacuum Wink )
kmwdesign777
adelaide
Re: boost gauge Sun, 07 September 2003 11:56 Go to previous messageGo to next message
It is probably more a concern for supercharged set-ups, but if your guauge needle jumps around like crazy under "boosting" conditions,then it is reading too much of the boost signal ie all the variations in pressure........so all you do is to put a restriction in the line with a 1mm hole or there abouts...this will smooth out the subtle variations and give better signal / pressure reading. ( or you can crush the line a little !!! )
regards kevin.
knackers
berala sydney
Re: boost gauge Sun, 07 September 2003 19:05 Go to previous messageGo to next message
hi
well when connected to a pressure line it dont work so any other help would be great.
thanks knackers Embarassed
Allan
Re: boost gauge Sun, 07 September 2003 23:00 Go to previous messageGo to next message
knackers wrote on Mon, 08 September 2003 05:05
hi
Get a bicycle!
Sorry but yeah best bet is let someone else check your oil and water also dude!
Allan
lumpy
Adelaide, SA
Re: boost gauge Mon, 08 September 2003 00:53 Go to previous messageGo to next message
Have you checked the line? When I installed mine (used a line from the intake mainfold) it didn't work - then we found the line was kinked as it connected into the cup (gauge holder). A little fiddling around and hey presto! A working boost gauge.
Make sure the line (or connection to manifold) is not blocked,as does actually connect to the manifold/whatever else you're using and you can feel vaccum from it when the engine is running. If it's a mechanical gauge there's very little else that can be wrong.
Re: boost gauge Mon, 08 September 2003 01:11 Go to previous messageGo to next message
don't use the vac line that goes to your power steering thingy... as that can have variable pressure in it at some points, not always the same as your manifold.
any of the others should be fine (I think). I spliced mine off the same tube my ECU was using, so I was sure it was a stable vac line.
btw - would it matter if I put the t-piece for my boost gauge right next to my ecu? I can't think of it causing any problems, but wanted to check before I go chopping more vacuum hosing
knackers
berala sydney
Re: boost gauge Mon, 08 September 2003 05:38 Go to previous messageGo to next message
thanks dudes for all your help
As for you allen no wonder you live in melbourne Laughing Laughing Laughing
Allan
Re: boost gauge Mon, 08 September 2003 07:28 Go to previous messageGo to next message
knackers wrote on Mon, 08 September 2003 15:38
Well all I can say to that is my boost gauge worked first time Razz
Allan
knackers
berala sydney
Re: boost gauge Mon, 08 September 2003 07:37 Go to previous messageGo to next message
Allan wrote on Mon, 08 September 2003 17:28
Allan
so what color dress you got on to day Razz Razz (_*_) Laughing Laughing
Re: boost gauge Mon, 08 September 2003 08:58 Go to previous messageGo to next message
draven wrote on Mon, 08 September 2003 11:11
think of it is as buffering the ECU signal, it will slightly slow the resonse of the MAP, but if you have a lumpy cam, it might actually help smooth out the signal.
personally, unless i had a problem with fluctuating MAP signal, i would use a seperate tube. but it may be no problem at all.. best would be to datalog the MAP signal with and without the gauge connected, and see what happens to the signal.
knackers
berala sydney
Re: boost gauge Mon, 08 September 2003 09:16 Go to previous messageGo to next message
hi stewart
this boost gauge is on a mates rexie was having a look but he got it sorted out to day.So thanks for all the help anyway dudes
cya knackers
Re: boost gauge Mon, 08 September 2003 09:53 Go to previous messageGo to next message
knackers wrote on Mon, 08 September 2003 19:16
hi stewart
cya knackers
so don't keep us waiting.. what was the prob??? the line, the tap point, or the gauge itself??
knackers
berala sydney
Re: boost gauge Mon, 08 September 2003 10:28 Go to previous messageGo to next message
hi
Well should have none you get what you pay for the gauge was roo''ed not to worry Cool
cya knackers
Allan
Re: boost gauge Mon, 08 September 2003 10:38 Go to previous message
knackers wrote on Mon, 08 September 2003 17:37
Allan
ohhh im devistaed you dont remember the pink one of yours i borrowed!
Allan
Previous Topic:Ke26 wagon ca18det swap
Next Topic:MX83 and JZX81 Tech Data
Current Time: Fri Nov 20 11:58:46 UTC 2026
Total time taken to generate the page: 0.0060489177703857 seconds
