Toymods » Tech & Conversions » relay thing on the coil bracket
coronamark2
icon5.gif  relay thing on the coil bracket Mon, 08 September 2003 01:53 Go to next message
I went and filled my car up at the petrol station went to a mates, cars running sweet, go to leave and the car cranks over reeee reeee reeee,but it wont start, its got fuel the batterys not flat,its got a new starter motor, alternator, coil, voltage regulator and battery.
What the fck could it be?
[Updated on: Mon, 08 September 2003 04:51]
Re: freaky sh#t Mon, 08 September 2003 02:01 Go to previous messageGo to next message
If its got fuel, chances are no spark? Points, rotor, power to coil maybe?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: freaky sh#t Mon, 08 September 2003 02:08 Go to previous messageGo to next message
Yeah, spark....
coronamark2
Re: freaky sh#t Mon, 08 September 2003 02:19 Go to previous messageGo to next message
so check the points,rotor disi cap, leads?
the coils new so?
What could it be to just stop working can anything blow (like a fuse) that would fck it?
ra23celicachick
Mornington Peninsula
Re: freaky sh#t Mon, 08 September 2003 02:36 Go to previous messageGo to next message
If it was the engine fuse you'd be able to start the car but it wouldn't run. Maybe flooded the carby? I've had that problem. have to let it sit for a while. Maybe try and start the car with your foot flat to the floor.
coronamark2
Re: freaky sh#t Mon, 08 September 2003 02:54 Go to previous messageGo to next message
yeah i thought it might be fuel so i took the hose of drianed the fuel out still nothin, its not efi so it must be the dizzy if theres no spark right?
coronamark2
Re: relay thing on the coil bracket Mon, 08 September 2003 04:53 Go to previous messageGo to next message
My dad looked at it and says its the relay thing on top of the coil bracket, What is it and what does it do, can i bodge it to fix it or can i get a new one?
He said he bridged a wire over it and it started first click.
any suggestions?
Re: relay thing on the coil bracket Mon, 08 September 2003 05:07 Go to previous messageGo to next message
I think you are refering to the ballast resistor.
You can bridge it (I did that to my 18R-C engine for awhile), but to be honest I don't know the problems that will cause.
It's there for a reason so.... Best to go get a new resistor, they cheap and chips from autopart stores!
roger
Re: relay thing on the coil bracket Mon, 08 September 2003 05:29 Go to previous messageGo to next message
If it is the balst resistor you are talking about by shorting it you are providing the coil 12V this will burn the point out eventually. Best to get a new ballast resitor for a few bucks. or replace the coil with one that doesn't require a resistor.
coronamark2
Re: relay thing on the coil bracket Mon, 08 September 2003 05:32 Go to previous message
thanks dudes im on to a new one.
Previous Topic:AE86 suspension
Next Topic:KYB Shocks!
Current Time: Sat Oct 10 00:17:04 UTC 2026
Total time taken to generate the page: 0.0055148601531982 seconds
