Toymods » Tech & Conversions » sc14 questions
neat 20valve
sc14 questions Tue, 09 September 2003 22:07 Go to next message
hi all does the sc14 have the electronic clutch like the sc12,
hence am i able to turn off the sc14 with the flick of a switch,
(dont ask why i am just thinking aloud), all info would be good.
regards Craig.
Re: sc14 questions Tue, 09 September 2003 23:03 Go to previous messageGo to next message
Yes.
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: sc14 questions Tue, 09 September 2003 23:05 Go to previous messageGo to next message
Yes they do. I have plenty at the moment $325 inc freight.
neat 20valve
Re: sc14 questions Tue, 09 September 2003 23:18 Go to previous messageGo to next message
thanks for your replys people,
andrewvibert
i will put your name in my contacts and let u know if i need one, thanks again guys.
onejayzed
Re: sc14 questions Wed, 10 September 2003 04:36 Go to previous messageGo to next message
if you're planning a 'mad-max' style switch then forget it.
the clutch will burn out in no time (like a week) if you were to switch on the supercharger at say 4000rpm.
the only reason it has a clutch is to disengage it at idle.
neat 20valve
Re: sc14 questions Wed, 10 September 2003 06:26 Go to previous messageGo to next message
i was thinking more like switching it off all together for daily use to and from work and hwy use. swith on and off only at idle.
onejayzed
Re: sc14 questions Wed, 10 September 2003 06:33 Go to previous messageGo to next message
if you were light with the throttle like mrs joe average and her 1.6 kids it would give better mpg than a std car thanks to the more efficient burn you'd get with the 4.5psi that the std blower gives (if you were to use the 1GGZE pulleys that is).
it would improve your swirl no-end, which is why these blowers are a great retro-tech fitment onto older 2 valve and non-crossflow engines, because the cylinder filling is improved upon.
CLG
Perth, Western Australia
Re: sc14 questions Wed, 10 September 2003 06:36 Go to previous messageGo to next message
onejayzed, what's your experience with switching the blower on and off? Was gonna do this to a recent AE86 conversion I've done for someone, after he asked after it, can it be done successfully? Can he run the the motor with out the blower operational, or will that blow the clutch too?
onejayzed
Re: sc14 questions Wed, 10 September 2003 06:44 Go to previous messageGo to next message
no it won't blow the clutch.
think of it like a normal clutch, if your engine's doing 4000rpm and you ride the clutch to get going (and there will be resistance on the blower because it has to produce pressure) you will have no clutch left soon.
but if you run your car with the clutch disengaged, it won't destroy the clutch, but you won't get anywhere fast either Razz
but what's the point of driving a car with a supercharger disengaged? the restriction would be horrendous, it would end up spinning the supercharger anyway to the point where it would provide just enough air to feed the engine, (and be a slug in the response department) so why not drive it and produce boost? it uses as much power to run as an a/c compressor, but gives back a shitload ( i think they're only underdriven by something like 9% or something....well under holden's shithouse attempt at 18%)
i'm retro-fitting one onto my L18 in my 180B with a draw thru 45DCOE and an off-throttle switch.
CLG
Re: sc14 questions Wed, 10 September 2003 06:48 Go to previous message
Yep, my thoughts too, but he wants it so he'll get it done! My turboed celica returns 9 - 9.5L/100Kms on runs where the boost runs around 1-3psi at 110KM/h under constant load
Previous Topic:Chassis Strength
Next Topic:Novice wheel tech question: offset & stud convertors?
Current Time: Sat Oct 24 09:57:44 UTC 2026
Total time taken to generate the page: 0.005357027053833 seconds
