Toymods » Tech & Conversions » 20V throttle bodies on 2TG
TRD-75
20V throttle bodies on 2TG Wed, 10 September 2003 01:06 Go to next message
i'm not to sure on the bolt pattern of the throttle bodies.is it much hassle to fit these to a 2TG? has anyone done it before?
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:16 Go to previous messageGo to next message
I doubt the 20V throttle bodies are a DCOE pattern.
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:17 Go to previous messageGo to next message
It could be done if you fabricated an adapter between the throttle bodies and the 2T-G manifold. It certainly won't just bolt up. If you want ITB's without the hassle of fabricating stuff, you can get DCOE pattern throttle bodies which will bolt right up to any DCOE manifold (which is what the 2T-G has). These are available from quite a few manufacturers, including some big names like Holley.
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:19 Go to previous messageGo to next message
Motec, Speed Technolgy and Injection Perfection all sell DCOE style throttle bodies which will bolt straight up to your twin Solex manifold.
TRD-75
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:21 Go to previous messageGo to next message
yeah i know about the aftermarket quad throttle bodies but i got told they cost about $800 for one with the webber/solex bolt pattern. does this price sound right?
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:27 Go to previous messageGo to next message
A full "kit" of twin DCOE throttle bodies and all the linkages/fuel rail will set you back around 1K minimum. Then you need to buy some injectors.
What I would do (if you have the 20V throttle bodies already) is get the bottom half of a 2TGEU manifold and fuel rail. Take it to a machine shop and get them to make a plate that matches the 20V throttle body spacings and stud patterns. Cut and shut this to the manifold. Hopefully the runners will not need too much modification to match everything up. That way you have the injector holes in the right spot, you can use a Toyota fuel rail and ND injectors.
TRD-75
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:31 Go to previous messageGo to next message
so don't the 20v throttle bodies have holes for the injectors?
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:34 Go to previous messageGo to next message
Not sure.....if they do then ignore my comment about the injector holes.
Maybe I am getting confused with the 3SGEs...their injectors mount in the head.
Ben Wilson
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 01:48 Go to previous messageGo to next message
The 20v throttle bodies don't have injector mounts. Having built up adapters for them in the past, I'd suggest getting some speed technology ones. Much easier.
TRD-75
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 02:00 Go to previous messageGo to next message
any idea of cost and where i could det the speed technology ones from? i've never heard of them before.
Ben Wilson
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 02:04 Go to previous messageGo to next message
http://www.speed-technology.com/
In Victoria..
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 02:12 Go to previous messageGo to next message
Or try these guys:
http://www.injectionperfection.com/
and in particular here:
http://www.injectionperfection.com/html/default_fo ur_cylinder_price.html
[Updated on: Wed, 10 September 2003 02:25]
EMP-2TG
Carlingford, Sydney
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 09:03 Go to previous messageGo to next message
this will probably be the next big step with my car
may be awhile off yet
and still not sure what comp to run with it
thinking i may give megasquirt a bash
Bill Sherwood
Brisbane / Gold Coast
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 12:47 Go to previous messageGo to next message
Just use the existing Solex's as throttle bodies, and add injector ports into the inlet manifold.
EMP-2TG
Carlingford, Sydney
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 13:17 Go to previous messageGo to next message
yeah this is true Smile
hows the 3sge coming along?
Bill Sherwood
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 22:29 Go to previous messageGo to next message
It's mechanically pretty much all done, it's just wiring & plumbing to go mainly.
I'll do an update of it on my home page in a week or so.
EMP-2TG
Carlingford, Sydney
Re: 20V throttle bodies on 2TG Wed, 10 September 2003 23:47 Go to previous message
nice Smile
ill look forward to it mate
Previous Topic:4AG(Z)E in a AE71
Next Topic:4agze or silvertop 20v????
Current Time: Sat Oct 31 13:17:09 UTC 2026
Total time taken to generate the page: 0.014726161956787 seconds
