Classifieds » Miscellaneous » MSD 6a multi spark ignition for sale
TWSTD
Auckland, New Zealand
MSD 6a multi spark ignition for sale Wed, 10 September 2003 02:48 Go to next message
MSD 6a Ignition. Part number #6200
$375 NZ
(Info from MSD web site www.msdignition.com)
The 6A is a capacitive discharge multiple sparking ignition. It will increase overall performance. Multiple sparks ensure complete combustion of the air/fuel mixture.
* Improves power
* Quickens throttle response
* Smooths out idle and starting.
* Reduces spark plug fouling.
* Improves mileage
SPECS:
- All sparks, including each multiple spark, is 110 milliJoules of spark energy.
- Steps up the primary voltage to 470 volts.
- Spark series lasts for 20° of crankshaft rotation.
- Operates at full power with a supply of 10 - 18 volts and will run down to 5 volts.
- Cast aluminum housing and Humi-Seal coated circuits protect the electronics.
- Can be triggered using points, electronic ignitions or magnetic pickups.
Item was in good working condition when removed from vehicle. Copy of wiring diagram included. Shipping extra.
http://forums.toymods.org.au/index.php?t=getfile&id=1931
Attachment: MSD 6200.jpg
(Size: 72.09KB, Downloaded 81 time(s))
Rotorise Me
Re: MSD 6a multi spark ignition for sale Fri, 12 September 2003 04:11 Go to previous messageGo to next message
just out of curiosity:
what sort of cars can you put these on? both efi and carby?
what are the proven power increases?
how hard are they to install?
do you just rip out you standard ignition and put this one in?
TWSTD
Re: MSD 6a multi spark ignition for sale Fri, 12 September 2003 04:16 Go to previous message
Yeah im pretty sure u can run these in carby and efi cars. As far as im aware it intercepts the ignition signal and boosts / modifies it Smile It has several types of pickup for diff cars.
Americans claim 5-10% power increases. Persoanlly id aim more towards the 5% than the 10%
[Updated on: Fri, 12 September 2003 04:23]
Previous Topic:CT12 Turbos - Perth, WA
Next Topic:ta22 diff
Current Time: Sat Nov 21 02:07:17 UTC 2026
Total time taken to generate the page: 0.0044069290161133 seconds
